if that was the case, then 1/2 psi extra boost on a car with STD internals would take care of that.
Peeps generally do a rebuild with forged pistons and aftermarket rods to be able to cope with more HP, RPM & strength.........not for better response.
Alot of people dont realise this.
Driving home today i noticed the RB30 in my daily driver has done a bottom end bearing....sucks considering its a really tight motor, Brand new head, no lifter noise what so ever. So thats a job for the weekend. :laugh:
ive teed it up with ryan to have my new rotors installed when they arive, now to find a decent set of pads, and fluid.
:laugh:
Craig, Steve Madaz & I are doing our brakes soon with the EBC Redstuff....I've looked long and hard for a pad that has good cold bite for street use that's reasonably quiet, has reasonable fade resistance for light track work, low dust effect and without being too aggressive on rotors.
If you remember I posted this thread Brake Pads and the general consensus from the likes of Evil34, PureSX, Ryan & Jenkies (just to mention a few) was that the EBC stuff is pretty good, not to mention cheap and available on the Groups Buys .
The EBC Greenstuff seems to be good for street use but the Redstuff would be better for street/light track work, plus they're ceramic so very quiet & low dust. The Yellowstuff seem the way to go for heavier track work but also dustier, noisier and more aggressive on your rotors.
Hope this helps
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
