used a wire wheel tonnes of wet and dry sand paper, undercoat and some decent paint. colour was tungston i think.. commodore colour :P
all up two full days
just temporary till i get them all blasted back and powdercoated properly
Might get mine done in a light grey.
yeah Roo that why you dont show up to the auction at all send your man in your place and have a phone link with him :P muhahahaha
thats actually very good advice. Make sure you also tell the agent that if the vendors insist with the auction going ahead that your offer may not be there at the end if it gets passed thru for less.
Nah this is what he meant. Theres the hose which goes from the turbo to the actuator. He said that apparently this was not meant to be, but there was
meant to be a solenoid that went in between it from Nissan factory. At this stage he had already passed me so i wasnt going to argue much, but i mentioned
that i thought they only came out on later models like 33,34. Bleh i dunno lol >.>
Congrats Min! Hopefully get mine passed next week so I can get back to driving it again! :D
Thanks Luke, just pray you dont get one of the younger looking guys. They looked fairly tough. (As in following the book down to the line@!) I got a middle aged
bloke who happened to be in a happy mood. I guess i got lucky!
My new tie rod ends has arrived awesome :D anyone fitted these before? Should I fit them myself I'm not sure because getting the adjustment exactly dead-on on both side looks to be a pain or should I have some suspension place do it so they adjust it and get an alignment done aswell?
If you need a hand mate, ill help ya out!
and MIN, yea Boost solinoid was a two stage bleeder which switched from 5psi to 7psi at 4000rpm on RB25DET!!! The Guy is obviously confused..One of robert's 33's didn't pass tier 3 because of this exact reason. The hose from the compressor housing to the actuator is stock so no stress mate.
Guest
    • Well, turns out not a lot happened from back then to now, between life again, and working on 3 separate other cars (only one of which was mine, and will now be departing the household soon).   So I decided with the whole "don't go outside, it's a cyclone!" Turning in to being not a whole lot, I ventured down to the garage, found a couple of water leaks in the shed (the main one I've already fixed), and then ended up "stuck" as it started pouring rain, and I didn't want to walk back inside in the pouring rain. This meant I ended up taking a look at the Skyline, and trying to work out what past Matt had been upto. I retraced a few things out from scratch, added the rest of the power feeds in that I needed for the indicators, and headlights. Double checked I'd wired a few things up correctly (and worked out how I wired a few things to begin with), updated my sparse notes. Added one of the ground points. Oh, and got really really dusty, as the car is quite dirty. Wrote up quickly what should be left for me to do with the wiring too. Adding the below photos more for my records than anything else. I need to make myself a proper book for the car that details everything, and how I've done it, but for now, this is my records... The third image is my most important one for me, and I need to draw it out into a proper schematic eventually. The last photo is my re-written list, I'd have put it on the white board, except I had to take the white board down to fix one of the water leaks.
    • Can try Maxima. Or random Infiniti models from the same era. Good luck with your hunt, let us know what you find!
    • Shall we... wake you up when September ends?
    • I got the Repco video recommended on YouTube.
    • Welcome Mark. Do you have a Skyline or are you looking to get one?
