When I first bought the R32 going on 8years ago the coolant temp sensor was dicky.. First summer engine temp went from 1/4 to half. I was wondering why the car would get really sluggy and on occasions stall and then not start until it would cool. Water would constantly blow out of the overflow.
Summer past; replaced the coolant temp sensor to realise it was constantly driving around on H. Maxed out the gauge. :S
It went on to clock another 100,000km's. :bunny:
:/ unkown engine cruelty :P
yours revs that hard? :O
mine hits limiter at 6900....
i want a 26 :(
RB20 ftw, I've seen 8500rpm on many occaisions (when I bother to look at the tacho mid slide). Another 100 or so and it hits the limiter, my old AE86 didn't even rev that hard :bunny:
Guest
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
