Aww happy driving that's a longggggggggggggg trip! Hope your not doing it by yourself?
Nah. Got the missus doing some of the driving also. :rofl:
also got loads of DVDs to watch on the way there, so will be entertained nonetheless.
good work Luke shall we go wash our cars before villies :D:(
zip lock bag Joel then you can play with it too ;)
It is the 1991 Winning GTR.
I made one mistake... I couldn't handle it sitting in the box so I removed it and shoved it in a plastic box to look at every day lol.
working good so far cheers heaps man - i will know how much better economy when i fill right up tomorrow
hey steve hows the afm going?
good looking trailer matty is that like phase one and when you get some more reddies make up a frame and put a skin on it
for those going to Blanche town i lived there for about 6-8 months when i was 18 :D boy never done so much drinking in my life - i worked in the Pub and in the bottle recyclers :D
Pete - got your pads today :D:thumbsup:
Awesome trailer matty!! :thumbsup:
We will be building one soon..Have you got specs on it in another thread?
Nah, no specs anywhere else jess, but can find out what design my mate built it from.
Basic specs i know off the top of my head (as its been built to suit my 31)
Deck (being usable area)
Length: 4.5m
Width: 2m (suits 1.8m track of my 31)
Ramps: 3m long, weight ~50kg each (mainly due to the 4mm thick mesh we used)
Axles: 2x 1.4t 45mm square axles with 10" electric brakes mounted on 6 leaf roller rocker suspension ("spring under" configuration.....could have done "spring over" but would have raised the overall trailer height by 4")
Trailer is unoficially rated at 2.8T (purely on max axle rating), but after shepparton we're getting it all looked at and the thumbs up given.
Loving that trailer.
Whats the chances of you knocking me up a nice one for a motorbike?
If you're keen for a motorbike trailer, i'll give ya my mate's number via PM and you can discuss the exact needs with him (he measured up my car to specifically build this for me, but handily suits most nissans..............wont fit a hachi or anything smaller though)
And some more piccies..............with the car loaded on
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
