hey chaDD when u get ur turbos?
Hey AdriaNN, i dont know, its been over a month since i paid for them and they still have not been sent, i sent an email and am waiting for a reply, if i dont get an email back in the next few days then i will have to do something about it. :thumbsup:
hey Ryan, im thinkin of gettin an LSD centre or mini spool in the 31, what are your recommendations ?
Hey kisin, being 28 spline and borg warner i believe the EA-EF XR6 LSD centre is a straight fit. I looked into this years ago but ended up welding up several diffs and eventually wackin a minispool in. If you hit up the 31 forums im sure there is some info on the xr6 LSD centre, PM DVSR31 and ask him as i believe he did this a few years ago. OR you can have the LSD out of my silo and ill have your open wheeler for small cash bonus my way if you want :thumbsup:)
hey all,
i am thinking of pushing my rb25det to 300 rwkw been told by many the engine will handle it!
just want to know if everyone else thinks the same, thanks
what turbo are you thinking of using craig? There's heaps of topics in the forced induction thread about this so have a sus mate.
All the rb25det's I've known to last have had the headgasket done and a set of cams to make 300rwkw reliably.
True, but there's a few that have lasted that are unopened...Mafia on these forums has had an unopened rb25det for quite some time pushing on 300rwkw....but as the saying goes, its all in the tune. The most common failures on rb25's is the ring lands (mainly on no6) but once again that comes down to the tune. Being a higher compression motor its very wise to change the headgasket to a metal one i think 1.1mm thick (dont quote me on that).
Edited by Ryanrb25
Cheers Ryan!
Jess, sadly that's the police and their priorities
Yeah I know what you mean, we know our local highway patrol by first name cause get pulled over a bit :down:
It is the 1991 Winning GTR.
I made one mistake... I couldn't handle it sitting in the box so I removed it and shoved it in a plastic box to look at every day lol.
Very Nice!! I got one of them, now just need to get the winfield car at a decent price! :rofl: dont really wanna pay up to a $1000
Nah. Got the missus doing some of the driving also. :rofl:
also got loads of DVDs to watch on the way there, so will be entertained nonetheless.
:D
haha good stuff!
You definately need a bit of entertainment on teh way, not much to look at :D
has anybody been able to find the 1991 or 1992 bathurst on Video or DVD yet..........Andrew (Nightcrawler) any luck bud?
They sell the 91 -92 bathurst race highlight's dvd on ebay : http://cgi.ebay.com.au/Highlights-of-Bathu...Q2em118Q2el1247
I used to have a copy it's really good watching and bit of a laugh at the old the commentary and channel 7 :)
Nah, no specs anywhere else jess, but can find out what design my mate built it from.
Basic specs i know off the top of my head (as its been built to suit my 31)
Deck (being usable area)
Length: 4.5m
Width: 2m (suits 1.8m track of my 31)
Ramps: 3m long, weight ~50kg each (mainly due to the 4mm thick mesh we used)
Axles: 2x 1.4t 45mm square axles with 10" electric brakes mounted on 6 leaf roller rocker suspension ("spring under" configuration.....could have done "spring over" but would have raised the overall trailer height by 4")
Trailer is unoficially rated at 2.8T (purely on max axle rating), but after shepparton we're getting it all looked at and the thumbs up given.
If you're keen for a motorbike trailer, i'll give ya my mate's number via PM and you can discuss the exact needs with him (he measured up my car to specifically build this for me, but handily suits most nissans..............wont fit a hachi or anything smaller though)
And some more piccies..............with the car loaded on
Very Nice Matty!!
Does the 31 overhang at the back much?
We need the long ramps as well, lucky the GTR front bars have that plastic lip at the bottom cause at least its flex's a bit as rubs when using short ramps
for EDDYFIER nothing major just a tweak i wanted to see how it looked with the rear transparent
EDIT
#2 is better with out line all around maybe
Cheers! :rofl: Yeah, the second one is definitely the better of the two. When I get round to taking some pictures for myself I'll make a new one up for you to tinker with. :rofl:
my whole server is down at work we cant do ant work or take orders lol and its national everyone cant do nothing
This one is for Steve
*Can't do anything
:rofl:
im bored.
EDIT thats better Steve
Edited by Damo_R34
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
