OK boys, the N1 Water Pumps have arrived........with a spare if anyone wants one (had to order 5 to get the good price).
1x Luke (ENR34).........PAID
1x Luke (Heslo)
1x Ben (Dohmar)
1x Pete (SLED)...........PAID
Very quick delivery........didn't expect them till next week!
I spoke to Martin Donnon when i went to willall today and im getting my car tuned tomorrow arvo.
The reason i went there was im very interested to see what sort of attitude and techniques some of the best known tuners have towards the same car. I'm happy with the tune from Jeff but im curious as to whether it can be done better and have different opinions of what the tune is like. Ill keep you all posted with what sort of feedback i get.
sounds good ryan, keep us posted on the out come.
im keen to see if there is greener pastures than my current work shop of choice.
i have the feeling my car is capable of more, with the right attitide and time spent toword the tune.
Finally, got my car back with no canary on the window! SO nice to have it back. As I picked it up from Synergy, turns out the police had a field day there and defect 10 of their cars for sale, most for "offences" like a pod filter which AFAIK is totally legal so long as it's fastened. Bad day for the boys down at Synergy that's for sure :(
I hope they got a good lawyer. Cops sure had better know what the hell theyre doing if theyre going to screw with someones livelihood.
Defected for pods? If it wasnt fastened then yeah they deserve the defect but if not, I'd be lawyering up.
Does synergy sell vehicles freshly imported or vehicles after compliance is performed?
-D
I'm cleaning out my garage and I have a set of R33 hub assemblies for the front (basically everything between the two swing arms), I don't know what they are worth though??
Can some one give me an idea of what I should put on them? (Note this isn't a for sale post)
They were included in the sale when I bought the brakes for a brake upgrade on my 180 so I didn't purchase them separately .
Edited by D_Stirls
Shit someone's quota must be looking pretty flash now.
SAPOL. Revenue > Respect.
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
