^^ no it aint me and heslo are going there for dinner and fishpaste so those that want come and join us :D small drive after too nothing planed no notes just a head drive
What time you guys meeting at Villies???
so, i basically f**king hate my work right.
a little over a week ago i filed 2 leave requests, 1 for the 8th of august for gokarting. and 1 for the 9th of august for the blood donation.
they didnt approve either of them! 700 staff with the training to take my shifts, and they "couldnt" arrange it. not even with more than 3 f**king weeks notice. :D
pisses me off.
Why would you sell your car if you lost your licence? I dont see the point. Im hanging out for the next 2 months to be over, get my L's and drive it again. And why such a 'quick sale' just because they lost their licence, seems abit fishy to me..
yeah, id say theres something dodge about it. as said earlier, the only pics are at the auction house.
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
