that mani wont crack ryan... its already been all gusseted etc, good welds, all been ported and cleaned up and it's not a cheap shitty china mani..... it's the good stuff.
But you already knew that. :down:
Should see my new mani.... :D:D:D:D yum yum..... and the screamer out the bonnet.
i personally agree with Craig i liked the drifteks but its not about what i like :down:
what did you clean your rotors with and does it cost much because i should maybe clean mine so i can paint the hats
you got much paint left :D
I just used wax and grease remover, or thinners will do, there was so much oil on the disks, when i was bedding in my pads it looked like my car was on fire :D I still have to paint and fit my rear rotors, but i should have heaps of paint left for you to use :down:
I'd go the 33 personally, RB25's are alot better than the 20's IMO, then again you could go a 32 and chuck in a 25 motor
The 33's are damn close to the price of a 32 these days..
33ftw.. better motor better gearbox to start off with. Much better modding platform that won't hurt your wallet as much.
I've also heard that I should go for a non-Turbo first, especially since I'm driving an auto atm. Seems like a wise move IMO.
The 15k includes stamp duty, rego and insurance for a year (so about 12 or 13k for the car itself).
Edited by normangerman
12k ono for my 32 with an auto
or its going into smooth garage on tuesday to get a manual converstion with HD clutch and ill let it go for 13k-13.5kono
if you keen check my forsale thread!
http://www.skylinesaustralia.com/forums/R3...y2-t226674.html
Edited by Import S13
Guest
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
