Just a quick question, I spose many of you guys feel the same, but I'm selling my AWD Auto Subaru Liberty and want to get a Skyline. Dads not letting me get a turbo and I have persisted but only got yelled at some more.
His excuse is 'you never know when the turbo will kick in and throw you sideways'. Thats about it. 'It would be irresponsible of me to let you get a turbo', 'Not at 17 years old' and all that stuff.
Is there any hard facts about this that can be to my advantage? Stock boost does crap all? You can't feel it? etc etc. He'd let me get a non turbo R33 (140kw) but not a turbo R32 (158kw). 'The disk brakes on the R32 explode and they're generally the worst one of them, the R33 is the pick of the bunch'.
Any common problems the non turbo has that the turbo doesn't? This is concerning both R32 and R33 models.
And for anyone saying how I'm going to be irresponsible and all this stuff, I've had this drilled into by my Dad more then enough. When I go driving with my mates I tell them not to speed and don't care if they get ahead of me. They do stupid stuff and I know who's car not to get into. Even complaining to my sister she reckons I'm the most responsible 17 year old she knows. Ask Kahli on here for some backup, she knows how I drive.
Thanks for any replies, but this is something I really want (I've already bought a car that was 'alright I guess' but not what I want. I don't wanna do the same again). Plus if I get a non turbo, my mates have already got a nick name lined up for me :rofl:
LOL well i came from a vs auto to a stock standard 32 gts-t, yes there is a power dif and i would def reconmend getting manual as i find it alot safer. In the end u aint gunna get sideweays unless u put ur foot down no matter what car u have!
hows is comming on at a certain rev range every single time 'you never know' going sideways is simple DONT clutch kick
common problem with non turbo is lack of power when you need it
Thanks for any replies, but this is something I really want (I've already bought a car that was 'alright I guess' but not what I want. I don't wanna do the same again). Plus if I get a non turbo, my mates have already got a nick name lined up for me :(
DONT listen to him thats the expensive way around
find a r32 with a rb25de and when ur older slap a 30 bottom and run 250+ rwkw :D lol
lol +1
So the post whores are back in town :rofl: was very quite without you guys :(
ah, so SAU isnt :D'ed from blanchetown thats good to hear :P
Yes, a couple of noticeable absences, CHAD AND JENKIES! Will probably be doing it again soon tho, was awesome fun!
and this talk about RB30 bottom end gets very expensive very quick if you dont do it right the first time which is moderately expensive
oh cool ill drop that water pump off after work sometime this week you name a day i finish most days @ 7pm but tues will finish @ 5:30
I appreciate that steve but this week is really bad. We've had a close friend suicide and I honestly don't know what my movements are going to be this week... ill msg you and work out a time later
-D
4wd yeah its a pain in the arse as there is the plenum issue if you run an rb25det. Typically for a 4wd you can budget an additional 1k over a std rb26dett rebuild. If its the rb25det then you need low mount plenum.
RWD - the additional cost is very minimal and well worth the huge amount of mid range compared to the 25. No reason it should cost more than an additional 300-400 max.
Back when I did mine it worked out cheaper to do a std rb30 freshen up with an rb25 head than it was to grab a rb25det and drop that in.
ur lucky to get a non turbo r 33!
i was only allowed a front wheel drive!!!
Guest
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
