Grab some carby clean. They almost always gum up and cause idling issues.
Does the valve AAC valve need removal for cleaning?
If its idling too high there's another valve that may be the cause. IAC valve. The spring can dislodge and cause a constant 1000-1500rpm high idle.
Can the spring be relocated or would I need a newbie......also can a good hammering up the hills cause a dislodgement because its been like that ever since I went for a run with my mates Porsche & Maserati (gave it a bit of a hammering that day :blink: )
Yeah mine idles way too high. I'm guessing the AAC valve is the accessible the one near the fuel filter which can be cleaned whereas the IAC is probably the "cold air by-pass solenoid" which is against the sandwich plate under the centre throttle body which requires a plenum removal and which can't be cleaned (approx $220 new).
Also Cubes, have you got the full specs on your Tighe cams ie. IN & EX opening & closing times etc......I might look into them myself.
Can the spring be relocated or would I need a newbie......also can a good hammering up the hills cause a dislodgement because its been like that ever since I went for a run with my mates Porsche & Maserati (gave it a bit of a hammering that day tongue.gif )
I do have the cam sheet. All though your requirements will differ as you are blessed with solid followers.
Tighe did reduce the base circle some what however it doesn't appear to have created any problems.
http://www.skylinesaustralia.com/forums/in...t&id=173055
Unsure if a hammering can cause it to dislodge.. Possibly.
Grab a can of start ya bastard and check for vac leaks bfore you go to the trouble of pulling everything off.
If the spring flicks off you can hook it back on and secure it a little better.
The std gasket will most likely break so grab some ACL gasket paper (the hard yellow paper) as its the correct thickness.
how hard is it to un wire gtr injectors with resistor pack??
If you have used a 280zx/R30 style resistor pack its as simple as heading down to the local auto store picking up a Navara 8pin? from memory plug and connecting each pin to each other (bridge) via wires. Then remove the resistor pack and plug in the bridged plug.
Hey guys just a quick question, i have a massive coolant leak at the back of my engine im pretty sure its just the heater hose leaking, any ideas how hard this is to replace??? or any idea's what the leak could be from its right at the back of the enging just infront of the fire wall.
hmmm I seem to be having absolute shit luck this year. Swapped the Chaser for a stupidly worked JZX81 track car and a Cressida Grande. Over valued the cressy to the tune of like 3k, turns out the thing is fair f**ked. Lost my job so had to swap the 81 for the 32 I'm in now, didn't get anywhere near enough coin on top. Lost about 6 grand or so in those 2 transactions. Now the Cressy has blown a head gasket (even after being torqued to the proper specs - good old 7M :() and the 32 is missing 1x rear quarter.
Roll on 2009 :)
Anyone know how to untighten the screws on the front of the fuel rail? Or what i can put on there so its easier to get them out? In heaps tight and i need them out to replace the o rings. Start fixing some small problems before i start driving it again in 2 months.
hmmm I seem to be having absolute shit luck this year. Swapped the Chaser for a stupidly worked JZX81 track car and a Cressida Grande. Over valued the cressy to the tune of like 3k, turns out the thing is fair f**ked. Lost my job so had to swap the 81 for the 32 I'm in now, didn't get anywhere near enough coin on top. Lost about 6 grand or so in those 2 transactions. Now the Cressy has blown a head gasket (even after being torqued to the proper specs - good old 7M :( ) and the 32 is missing 1x rear quarter.
Roll on 2009 :)
Aren't Cressy's prone to warping head gaskets? My mates Cressy which had a 5M in it blew 2 head gaskets within 6 months :D
Yeah man cressys eat gaskets like they're goin out of fashion :) Its the head torque that is the problem. Mine has been re-torqued and still fked the gasket out (to it's credit, it did complete about 10kays worth of driving on the H with the bottom end rattling away before the head gasket went :))
I reckon I'm just gonna get a Falcon and stop spendin money modding cars for a while. The Falcon seems to be best suited to daily with occaisional towing duties, so I can still get the busted arse 32 out to the track to thrash, Crazy Max styles with munted rear quarter. At least if I hit the tyres on the entry to 1 it doesn't matter because that quarter is already f**ked :laughing-smiley-014:
what suspension matty?
kyb shocks, aurora springs.....7kg front, 5kg rear, standard size (but slotted) aus del front and rear brakes too................nothing special in pads, and they didnt fade or cook
Guest
    • Wideband is worth setting up if only for tuning purposes. I would not mess with the ignition system unless there's a misfire. HKS crank trigger is popular out here for the relatively easily sourced Denso crank sensor, not a bad idea to install as well regardless of power level on a standalone. Boost leak test is worth thinking about. Oil pressure sensor tied to a fuel cut isn't a bad idea either. Getting the tune figured out is a good idea. Without putting eyes on it and getting under it there's no way for us to tell you exactly what it needs but most likely you're down to the last 10% that will make a big, big difference in how happy you are with the car.
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
