if tangles happens to wander through here,
been reading through the 'rise and rise of kevin rudd' thread in the wasteland to kill time, and i like the way you think mate. :)
Bosch 023 is the next step up from 040 and can handle roughly 200hp more (~800hp) , and it still fits in-tank ?
That true ?
Is it worth getting this just to be safe (unsure how hard to push the engine at this stage...) ? I saw 1 on ebay for ~$195 delivered. (Says its genuine Bosch). Steer clear of ebay 1s and go get it from a shop ? Anyone using this pump ?
Thanks
Edited by KISIN
Does anyone know who would be best to fix up the trim on my Momo Wheel? it is splitting at the seam, but the condition of the leather is still good, so looking for someone (motor trimmer perhaps?) to essentially glue it back together with the correct adhesives.
Cheers
i have what i thought was a 32 gtr wheel, but appears to be a 33 s1 wheel
had it since january....horn didnt work cos of a different setup to the 31
has a slight worn patch at about the 7 o clock position
if it works for ya steve ya can have it
http://www.drambuieresearch.com/
Hmm bogans and drambuie do they mix lol :cheers:
ROFL i heard you like it but...
can anyone answer this
ORC TSUINPURETOKURATCHISETTO RB26RB20BNR32BCNR33
will that clutch suit a GTS4 push type ??? :w00t:
this is what i want to get
also does anyone know how much meat is " Disk remaining two are 4.07 mm so still usable. "
i had 3hrs sleep today and had to go to observation day thingo with
this place i had an interview with on Monday.
it went quick so it was good ;)
oh my brother bought another Celica :rofl: , it's manual so
i'll be learning manual in that when they get it registered
(hopefully next week)
Guest
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
    • Stop looking at the garage floor, and turn the radio up a bit louder if there's any strange noises...
    • No. Turbo shuffle and surge/flutter are not the same thing. Specifically, on a GTR, turbo shuffle has a definite meaning. On a GTR, the twin turbos are assumed to be the same thing and to operate the same way, exactly. In reality, they do not. Their exhaust sides are fed and exhaust a little differently, to each other. Their inlet sides are fed and exhausted a little differently, to each other. Consequently, when they are "working" they are often at slightly different points on the compressor map compared to each other. What this means, particularly when coming on boost, is that one of them will spool up and start producing extra flow compared to the other, which will put back pressure on that other compressor, which will push the operating point on that other compressor up (vertically). This will generally result in it bumping up against the surge line on the map, but even if it doesn't, it upsets the compressor and you get this surging shuffle back and forth between them That is "turbo shuffle" on a GTR. It is related to other flutter effects heard on other turbo systems, but it is a particular feature of the somewhat crappy outlet piping arrangement on RB26s. There are plenty of mods that have been attempted with varying levels of success. People have ground out and/or welded more material into the twin turbo pipe to try to prevent it. Extending the divider inside it works, removing material doesn't. There are aftermarket replacement twin turbo pipes available, and these exist pretty mush purely because of this shuffle problem.
    • You can temporarily* use lock collars to keep it in place until you can do the bushes, back the nuts off, slide them in, snug back up. *temporarily is often for ever
    • Thanks for the quick reply. To be clear, when you say turbo shuffle do you mean turbo flutter "stustustu" or referring to something else? I had thought they were the same thing. When I wrote the post my intention was to say it wasn't a flutter/compression surge sound. My understanding was that a flutter sound would be occurring when throttle is released, whereas I can keep the throttle in the same position for this noise
