its no pike peak but looks good fun :P
skip 1 min in the footage at the start dont work right.
that is the actual 1 he bought, never been thrashed :( silly boy didnt wanna go through the hassles of buying off someone who dont speak english but surely coulda found a nicer condition 1
yeah cultus is a upper model 4wd we didnt get they go pretty damn good for a 1.3 but still nothing ground breaking ive heard there is a turb but this 1 isnt boosted. gti our local better model makes something like 65 70kw at fronts lil bit quicker than a vp v6 actually better comparo for you guys is its as quick as the old 88 skyline auto seen 2 races between em 1 vl (same diff) and 1 88skyline both dead even with the bog stockers
and the cino's ive killed many with my old dato
there's an orange cino getting around with some crazy kit on it pretending its a gti :( feel free to beat it in your dailys or your push bike people
if you on a crazy crap budget n need to save on fuel gti's arnt too shaby idea (flogging it still gets you 17k's per litre) but if you plan on modding your way to something powerful go a different route for god sake it'll end it tears n any fuel money saved will be spent on repairs.
i grew up with the old swift club so i picked up a fair bit on em :P i was always after a 32 gtr though
Edited by Inline 6
lol im far from good at maths and i got it.got any more brain busters there for me steve haha.hmm im currently sitting on a quater tank and have driven 334kms....and its NA :P ....i sure hope i can suck another 70kms out of it!
I used to get no less 500 kays out of my chasers tank, I think they're about 60L from memory. Once I got 670, and still wasn't on the fuel light :(
The skyline hasn't seen a proper full tank yet, and even then the speedo and odo don't work so I owuldn't be able to measure consumption anyway :P
seems like when the intercooler is cold it goes good but once it warms its gets a little laggy
might need bigger cooler or larger piping and not steel pipe work
Or you need a retune for your motor :P
Guest
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 🤣👍   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
    • Yeah, but knowledge of one wire's insulation worn through to short on earth implies the possibility of other wires doing the same. I had my power steering die, because the wire that runs to the solenoid valve on the rack runs in the same loom as the power wire for the O2 sensor. And when the O2 sensor/wire did something stupid and burnt part of that loom to death, the only indication was the shit(ter) fuel economy and the heavy steering. It took deep excavation of the looms in the bay to find the problem. Not wear through in that case, but similar shit.
