Auto box will be fine.. Get a tight shift kit in to her and she'll be fine. :ermm:
that was my last mod 2 months ago- should have been the 1st mod 2yrs ago
very tight shifting, very very happy with MV's work
worried about the wiring up job tho for the powerfc ecu + pin 51 resistor trick (engine check light) + attessa system (pin 23 I think from power fc ecu to attessa ecu)
but yeah not sure
will get Bostwerks to do the job, but need all the info. got some, but I dont understand electronics lol
:D
hi ;)
my hand hurts so bad from writing out these damn 21st invitations ;)
my knees hurt from walking, sitting, sleeping
wish the wernt in jars.
21 yay ;)
oh to be 21 again
Im now hearing pin 37 on the r34 gtt power fc controlls the attessa throttle position sensor (rather than traction control for the r34 gtt)
so tha should be ok.
just pin 51 and use the zenode trick to pull it to 3.7v from 5v
Guest
    • The only Neo rods that were any different to any other RB25 rods were the DET ones, and they were the same as RB26. Here is a Neo DET rod. O5U part number visible. Here is a post in a thread here on SAU with evidence from someone who has done this before. There are photos in the thread of normal RB25 rods.
    • Sure, but why assume that will be the case forever? And why assume you'll be able to do an oil change to swap back to a stock drain bolt before that happens? And does it even matter when I change the oil at fairly short intervals? Life can be funny sometimes and unexpected things can happen. Like breaking a collarbone so you can't do any work on your car for a few months but the oil change is due so you have to take it to somewhere and hope they don't do something stupid like stacking the new drain plug washer on top of the old one.
    • Do u know how to identify the rods are rb25 or neo ones? Can u look into the pics and tell me is they de or de neo ones. Its confusing becoz my motor has de neo head but block is 25de 75t, so really confusing me about rods, crank.
    • Are you talking about the oil squirters? There is only one place for them to go. Yes, you have to drill the holes. Yes you have to obtain the correct oil squirters (I presume there is some sort of aftermarket option available, because original turbo ones are going to be a diminishing resource).
    • I thought you didn't let mechanics, especially those with no idea, work on your car any more? Wouldn't that mean it won't be an issue in your case?
