while your doing that might as well slap a turbo on it :)
You'll need to remove the head if thats the case. Might as well throw a gasket kit at it while you're there, just to be sure. Drop the sump and replace the con bearings while you're there ... hell, re-ring it too. Check for abnormal wear and tear.
Best to spend an extra day and $300 freshening up the motor, just to be sure.
I did it will all my engines I picked up for cheap. :D
edit: oh, while the head is off, remove the valves and clean them up too.
your curve Joel from like 95 is like hold on and enjoy the ride :D
For Rad33 with his new rb25det on the way.. Get an rb30 under it. :P
RB25det vct head FTW for bottom end. :D
AL's motor is running the same GT3076 .82 on an rb30det but with a nice exhaust and inlet manifold with slightly smaller cams. The VCT has picked up some nice low end power peak power appears to be made around 7000rpm.
Now for mine.. :P 15.5psi that can be seen and the last tune at 19.5psi through the mid that tails off to 17psi causing top end to flatten out. The 2" fmic piping is causing issues up top as well as the wastegate flap being blown open.
Mine makes its peak around 6000rpm. Will play with the adj. cam gears to shift that to approx 6500rpm. :D
lol we could of told you that cars never miss behave once you get them to the mechanics - PM send about AFM's
So when the mechanics drive my car it doesnt shit itself?????????? FFS!
so where does that leave me? high and dry.
the only thing i can do is.... what for it to happen again and make sure it happens at the mechanics?
ill have to try and clean out the AFMs and check for damage.
Damo :D
Guest
    • I'm firmly on the "zero compliance is good compliance" for FUCAs. I'd be looking to solid metal joints even if the primary reason for having them is because they facilitate the twist in the arm. I have never been more happy with the way the front suspension behaves than I have since I got rid of the FUCA bushes. Even the thin little (short lived) poly bushes in the Whiteline adjustables have too much compliance for my liking. It probably won't be long before I have sphericals nearly everywhere, probably including both top and bottom arms in the rear, and I'll start complaining about the increased costs for dental work. But I will be enjoying the driving more, I'm sure.
    • Plus, you'll get great experience in bedding in pads!
    • I have offset Nismo brackets so the fact the gktechs can pivot is less important to me. I have 170mm JIC arms with bushings - but they provide no adjustment and I'm not sure whiteline eccentric bushings will fit them (I don't want to ruin the bushings currently in them to find out). Ideally I want something with bushings + adjustment; hence why I'd like to find a pair of these. Unfortunately they aren't easy to find.
    • @Vee37 How much do you really care about finding these pads again? If your pads are quiet, work well and produce minimal dust, really isn't that enough? If you are set on finding the exact pads again, I suppose I'd do something like this -  Visit your local Jax, find out what brand of pads they carry. If the Jax workshop you previously went to had the pads on the shelf, then you can almost guarantee it will be of said brand.   I'm guessing you don't have the receipt for the previous work and pads. Can you visit a Jax workshop and see if they can look up your previous job to see what pads were fitted?  Still no luck? Put your stalker hat on, find the staff that used to work at the Jax store and ask them. Talk to local workshops, try to find out where the mechanics went to. Talk to Jax workshops, maybe they relocated to another workshop. When it comes to mechanics, its a small world. You'd be surprised how easy it is to track someone down. If these ideas don't work, shit will start getting crazy very quickly.... You could find out every brand and model of pad that fits that car... and try them individually ticking each off the list if it wasn't the one you were looking for.... If you go down this path your going to want to learn how to swap pads yourself, it is very easy, takes minimal tools and space. If you have room to park the car you have room to swap the pads. Plus you have the advantage of making sure all the brake hardware goes back in so they won't squeal!
    • You miss spelled bearings...
