i need a r32 gtst SMIC asap!
ASAP like tomorrow? :( I've got the smic and I'm pretty sure 90% of the piping too. Send me a msg or PM on here (or both) tomorrow morning and you can get it tomorrow night with the reo if ya want.
$150 for reo and stock cooler sound aight?
Also just PMing you now to show ya where to meet :(
Yesterday I was having trouble with SAU loading at work for some reason, so I searched it via google to try link in, and to my surprise, look who comes up as one of the main items for a google search..
I think you need to slow down the posting or something steve, you're world famous now! LOL
Post whores the world over look upon Madaz with Awe and Respect
-D
morning people, how be we all?
So ive somehow made it as a finalist in this Zoo Real Car search, and currently sit in 4th place. Am hoping you guys and girls would be kind enough to maybe throw some more votes my way :D Only 2 vl's and celsior to beat :( You can vote as many times as you like but i am thankful for any votes (i do encourage more though :()
Here is the link to my profile where you can hit the 'Vote For Me' button -
>>>Vote For Me!!<<<
Thanks to all that do chuck some votes my way.
Cheers. Luke.
Edited by skylineguy19
Guest
    • Means something is not set up right, tune/calibration related.
    • Finally replaced the previous temporary mesh indicator surrounds (temporary was the last 10+ years 😂) with a 3D printed GTR style version for the front indicators. I think it looks a lot nicer than the old setup and at least the indicators now point in the correct direction rather than angled off. Needed a little bit of tweaking to deal with the intercooler piping but got there in the end. Old and new photos below.
    • It's weird to me that you say this because I'm pretty sure locals with relatively standard standalone tunes (boost/barometric compensated alpha-N) still have driveability issues when they pop intercooler hoses. Maybe with enough data I can just train some kind of model that spits out an expected grams/cyl given every sensor input except MAF like what FCA did with their Pentastar 3.6 ECU logic. Basically stock everything. The main motivation honestly is to have a sensor that can be a decent baseline source of truth. In scenarios you're describing obviously it won't work every time but it seems to me the number of corner cases that exist in MAF load is maybe not as severe and difficult to manage vs ITB alpha-N with some MAP/barometric compensation.
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
