damo, get a hand controller, its definetly worth it, alot of people have had their car tuned then gone to drive it on the road only to realise they have a higher than safe knock level because the tuner didn't take into account the dyno is only a tuning tool and not the same as driving on the road. Plus you can keep an eye on boost levels aswell and chicks dig it.
i accidentally posted this in the cars spotted thread lol, my bad....
im doing all my oil swaps this week, anyone with a 32 gtr got any advice???
so far i got
engine: motul turbolight 4100 10-40 or 5-40
diffs: Castrol SAF-XA
gearbox: castrol syntrans 75w-85 or syntrax 75w-90
and the transfer case, attessa & powersteer can use the same: castrol Transmax Z
advice????? also oil filter advice? this my first swap on a modern car, used to simple escorts
i have heard (and this may be bollocks) that this is a yakuza run firm.... and you will be lucky to get the car at all..
there are some jzx100's and 90's that make me happy in the pants on this site :banana:
this one makes me wet
so far i got
this is just some ruff notes i've got saved on my PC from a few years ago, nfi about if the prices are right etc, but it might help you figure out what you need
Engine: Motul 300V Power Racing 5w-30 $95/4lt, $38/2lt, $450/25lt
Manual Trans: Motul Gear 300 $24
Diff: 75-140???
PowerSteering: Dexron III: $9
HICAS: Dexron III $9
Brakes Motul RBF600 $30
Spark plugs: PFR6A / PFR5A (NGK platinum) - gapped to 1.1mm or 0.8mm if you are missing
Coolant: Nulon 9lt 50%
Transfer case oil: Nissan Matic D 1.8lt
Frount Diff oil: GL-5 85W-90 1.0lt 75-140???
Rear Diff Oil: LSD GL-5 80W-90 1.5lt 75-140???
Brake Fluid: RBF600
Clutch: RBF600
Power Steering Fluid: Nissan Power Steer fluid 1lt
Engine Oil: factory spec 7.5W-30/ 5W-30 4.6 litres
HICAS: Nissan Power Steer fluid 2lt
ATTESA: Nissan Power Steer fluid 2lt
Manual Trans: 75W-90 GL4. 4.1 litres - Redline lightweight Shockproof Gearbox Oil?
yeah +1.
Also important to note the ramp rate the tuner is using......Shoot Out Mode (200) is a waste of time for the street, should be 150 or it will definitely run in different areas of the map (detonation city) on the bitumen and up hills.
just had Ryan n the guys at AUSSIE DYNO N TUNE tune my car today had a few issues with wheelspin but after putting ryan in the boot gave it a few runs and pulled a constant 300rwkw then on the last run pulled 327.4rwkw on only 19psi with only 18 knock level!!!!!
great guys down there fully reccomend them 2 any1!!
great talking 2 u Ryan top bloke, ill be back there with sum softer tyres n maybe biggr injectors so we can screw sum more boost in2 it maybe.....
http://myspacetv.com/index.cfm?fuseaction=...ideoid=41815405
Edited by ovrtym33
Top effort.
What are the specs? Turbo exhaust manifold? etc :thumbsup:
The rb25 pfc can display a boost reading if you hook up a cheap map sensor.
Paulr33 has the info on in his PowerFC Faq on how to get it working.
Top effort.
CP PISTONS
EAGLE RODS
1.2 HKS HEAD GASKET
GREDDY EXHAUST CAM GGEAR
256' 264' HKS CAMS
TURBOSMART EXTERNAL WASTEGATE
X FORCE HIGH MOUNT EXHAUST MANIFIOLD
GARRETT GT 30/40 .82
POWER FC
555 NISMO INJETERS
TOMEI FUEL REG
CROWER VALVE SPRINGS
ETC..................
oooooo i might just do that, i have a feeling it's a "friends" friend coz she sent me a msg
saying she was getting threating calls aswel.
might get him to check out another number aswel, had 3missed calls from it then sent a msg
asking who it was and haven't got anything back from the number lol
Guest
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
