get these add ons craig
adblock plus
self explanatory really, blocks all those frikkin ads
download statusbar
statusbar that sits at the bottom of the browser, instead of opening a separate window
ie tab
allows u to open a page within firefox using the ie engine
smart bookmarks bar
love this one, strips the name of the url off the book mark and just leaves the logo
url fixer
fixes typos that u put in the address bar
How you can prefer IE over Firefox is beyond me Craig :P IE has to be the most horrid browser bar Safari for Windows. Well it's not computer jargon so I won't go into it but yeah, grab those extensions and you'll be sweet!
if your doing the lock bar then id advise doing the whole thing.
i did it on my old 180(same hicas system as 32), and its really not that hard. the hardest part was getting the tie rods out of the hicas rack. the rest is simple.
im trying to remember who i got my lockbar off of, hes on here, but i cant think of his username.
Guest
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
