Npz Luke and Yes Craig may even be $190
GUYS that go and See or Ring Ric DONT DONT DONT forget to tell him Steve sent you otherwise no discount
he has made up %15 loyalty cards which he will give me the next time i go in and i can hand some out but STILL need to say STEVE sent you
:banana:
You drive a Skyline, plates or no plates, you're still in the shit
Fecking LOL, truer words were never spoken :P
Also Nardi > all. I had one of those wanky bullshit Isotta wheels on my 180 and it was homo as to drive with. Nardi + 30mm bosskit spacer = win (or just get a Deep Corn for like $150 more :P)
nardi = win
i want to get one for the drift car, so much better than the Personal wheel i got on there at the moment
yays for RDO...............might start calculating the size of enclosure i can build for my subs in the patrol............. i know i need 26 litres per sub for a sealed enclosure, just gotta do some maths to work out how much i need to take out for the wheel tub lol
the threads were being monitored by their "legal representative". so even with warnings to people to keep their mouths shut, well we could see that working as well as the "dont post in here unless completely necessary". No one listens. Email sled [email protected] Adrian [email protected] or me [email protected] / [email protected]
Well I woke up this morning feeling much, much better ... flu all gone :banana:
Still groggy and overslept, but f**k it! Got things to catch up on. Still got the day off work. :P
just wondering if anyone knew much about greddy t517z x2 suit gtr. power potential, posatives and negatives
cheers in advance
I have seen these on a gtr with 700cc injectors re build and usual mods on 1.24 bar boost run 454rwkws... they are great turbo's plus they bolt into the stock location. i was planning on running these but im thinking of swithching to the GT2871R from CGU.. great responce not much difference from stock... hope that helps out a little i got a mag article with the write up on those turbos if ya wanna have a squizz
Rann really is a f**king idiot. :banana:
too f**kin right!
I wonder if they'll get heavy handed with all bikie association and whether that also includes the Longriders who are ex outlaws.
I have a couple of mates that are members, does that mean that I can no longer catch up with them once a month??
yeh there is no clear line drawn in the sand, i think you will see the law fall through in a few months, when they try to arrest or fine there first victim cause i can see way too many loop holes apearing
too f**kin right!
at the end of the day you are correct, there's no clear definition of what a bikie or an outlaw is. So if Roo or I have a sordid past, does that mean you're all in trouble if you come to Villis tonight?? Or will I be fined or arrested if I drop into their clubrooms once a month............ridiculous, they are EX outlaws so I'd like to see some defined legislation 1st.
are they laggy Mike?
did ya mean the CGU ones i plan on getting or the trust t517z?? cause the trust ones i haven't seen the dyno sheet but they're not to far off the N1's (supposedly.) and The CGU ones are basicaly the same as N1's but way better...
Guest
    • I remember the days when E85 was priced in according to the $ per km outcome. Sure E85 was about 35% cheaper, but you also lost about 35% range... now it's fked..
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to move wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
