lol is that all? its pointless explaining how wide you can go if you dont understand offset. google "offset", read up, then youll understand what we are on about.
wtf? please explain HOW it is pointless? i understand offset but that has no bearing on my question, i simply asked what was the widest rim you can throw on a gtr without it rubbing, and obviously you would state the offset for that size.....i can do without the smartass-ness :P
Edited by rhys5169
well, finally going to bed after pulling the wiring out of my bike frame for the past 6hrs
don't be too noisy during breakfast you guys so I can sleep in
you get home in one go?... you didnt seem to have any trouble on south rd
got my spacers on this morning @ wheelworx....
looks tuuuufffff!
but rubbing on the front guards even though they where rolled!
so wont be lowering it any more, i hot +25mm all round, so i should have settled for 20s on the fronts
but oh well, still looks sweeeet :P
question ,
my car has way too much power for an N/A , it revs past 7000rpm without a problem .
what would be the first thing to check to see if its got stock parts in the engine ?
cause there is no way it has 140kw~
lol yeah :P it was pretty much the first time i said it out loud... and it dawned on me
was good catchin up last night mate.. the celly sounds awesome btw
haha, love it when shit like that happens :P
cheers dude, still sorta think its a bit noisy, but i love the noise it makes jsut the same.
lol, yeah it rubs major on the fronts, rears are ok........
think i gotta go back for smaller and sell off the +25s
im not too keen on the look of the fronts now either....i need other ppls opinions :P
Guest
    • Oh man what a deal.... Funny enough (well not really) I sold a car to some old dude (buying for his Daughter) on a Saturday, He asked if she could take the car now and pay me the money on Monday as the bank wasn't open. Needless to say I told them to come back with the cash or get f**ked! Luckily the money seemed to magically appear in his pocket a few minutes later, so it all ended well (for me).
    • Gucci bags tend to hold their value well, so someone’s definitely going to get a nice find here.
    • @Ozdavroz Not going to get a better deal than that. Cash up front and ongoing payments. 🤑
    • I wouldn't even move it like gTSBoy is saying. I'd seriously do what Duncan is saying. Unplug the injectors, and unplug the fuel pump.  Pull the spark plugs out. Have a look in quickly with a bore scope if you want. At most, you can't spray a bit of oil into the bores so there is lubricant in there while you crank it. (Don't fill it, as it's only going to enter the exhaust, or spit at you out the spark plugs holes. Before cranking the engine on the starter, after a 5 year sit I'd probably prime the oil system manually. Easiest way to do so is to look at buying an oil filter relocation block, fit it to the engine. The pressure line going into the engine on this block you can then shove into some sort of oil pump, or put it into a bottle, with that hose going to the bottom. Fill bottle up with oil. Now seal the bottle and add a compressed air line to the top of the bottle. Feed compressed air in, about 20psi will be PLENTY. This will pump oil through the motor. Be aware, it also means it will drain back to the sump, so make sure you don't end up over filling the motor Now bolt the old oil setup back on (or fully install the remote filter system).   This way you've at least pushed fresh oil everywhere, then you're letting the motor crank to then do its own oiling. Then I'd tap the key to make sure it can start to crank, if the motor free bumps, then I'd just hit the key and let it crank. After letting it crank and seeing you can get real engine oil pressure, put new spark plugs in, reconnect the fuel system electrics, and send it.   Additionally, you can look to remove the fuel feed line to the rail, and divert it to a tank so you can get the bottom of the tank shit out, and just incase there's some crud sitting anywhere that gets passed the fuel filter (or is already ahead of it).   If fuel injection at the injectors ends up appearing to be a problem, you can dump the injectors into an ultrasonic cleaner for a quick flush clean out. Note this isn't as good as new injectors, or getting them pro cleaned and flowed
    • All I can say is, that's still bloody awesome! No plans on caging it I'm guessing?
