I don't think Kellie is in the mood to be helping people for a while. Perhaps give her a break and allow her to volunteer to assist. :)
kell actually spoke to me on the phone this arvo,
but thanks for your input ruby.
fishpaste~ and i were behind you, must have missed you on the side of the road (dont know how :P ) could have got a tow rope, and taken you back to your place water ski style :)
Yeah, we got WAY behind you at south rd/anzac highway intersection... can't quite weave threw cars like you can =P
We could see you up ahead, but I though you had safely turned down daws road, and we continued down south road... probably should have swapped phone #'s
ahh, thanks boys. I wanted to get home quickly while it was running fine but like I said, she broke down just outside the Tonsley Pub and I ended up rolling into Lloyd St, St Marys to avoid sitting on the main road for the next hour........I was only 1 km from home so a tow at 10kph might have been a good idea. Now I just have to go thru the threads to find a good mobile auto electrician cause I'm over working on it.
hey Pete would you be able to take a photo of your brake master cylinder on the GTR and post it up?
Just need to have a look at it before i put mine in.
Thanks Luke
OK Luke sorry it's taken so long but here goes.....the blue bracket is the support for anti flex.
EDIT: Thanks Carl
had a dinner party last nite at my place, it was great.
we supplied pizza bases, cheese, shredded ham sauces etc, and then got ppl to bring along other ingredients... easilly fed 19 ppl, and had some good times
had all sorts of gourmet stuff... the best pizza i made had satay sauce, chicken, onion, camenbert, and mango :)
Hi everyone, i was just browsing as usual.. and came across this thread that i thought might help you prevent theft in case you missed it.
http://www.skylinesaustralia.com/forums/An...ft-t231396.html
scroll down to the posts "waza" makes and there is a lock that prevents people from shifting gears when the car is unattended to.
I thought this might be useful for everyone that is paranoid about their cars being stolen.
Edited by TS-R34
just sold 2 of my 25mm spacers :)
will be going to wheel worx tomoz to pick some more up
not sure whether to go 15 or 20 :P
measure the point of the tyre that stands out the most to the top of the gaurd. will give you the best idea if you didnt want to drive the car to them.
or just do what i do and ask joe to let you test fit or ask for advise. dont want to end up were you were before :P
yeah, im gonna take the 25s off, and drive it down to wheelworx on saturday now,
ill ask for a test fit on the 15,
i want them to look good, but not rub, i want the best of both worlds :)
should have called you to meet up for entry forms today kye.... i was down at my auntys holiday house in aldinga
:P and i was home most of the day too. its sitting in the boot of my car so ill hook you up before friday.
flat tyre and no tyre shops open on a sunday is gayness. i dont trust those space savers!
Guest
    • Hey lads, reviving an old thread.  As an update, since the last time replied to this thread, ive done mostly suspension. Havent touched the motor except for maintenance. Though upon changing spark plugs, found out i had splitfires pre-installed! Updates: - Got me some stock airbox top cover and snorkel to fit onto the original intake. Should be free of defects - Bought a set of R34 GT-T brakes (not installed yet, going to rebuild + respray in champion blue + white 'Nissan' text) - Bought the last set of bilsteins from @Sydneykid and had them installed. Has been making some sounds on the rear but hopefully should be sorted out after this New Year break. - Regreased front caster rod bushings (poly bushes..) - Rear upper camber arms - Whiteline sway bars (BNF27Z 22mm + BNR11XXZ 24mm).  The rear sway bars are a bit short (ive read 50mm else where) but was still able to get them in.  Anyhows, I reckon suspension is sorted now. Maybe replace bushes (do have a set of front upper control arms from SK not installed yet) but should be okay for now. From now, I'm wanting to start working on the motor, drivetrain etc etc. Still debating on the order to go on and what to buy etc but: - ECU ( Haltech or Link ( Link states that it dont support A/T or AWD functions... Can anyone attest to this? ) - Highflow turbo ( ATR43ss2 ) - Intercooler ( Not decided yet, but cant find many good afoordable ones. Toshi says to opt for crossflow Japanese. Bit difficult this one, unless I get a returnflow Blitz from JJ? ) - Injectors ( Any recommendations ? I do have a nismo FPR ( Thanks SK ) ) - Seats - Tune by either Toshi or DVS To be fair, I did consider just keeping the stock turbo and nistuning it. Sat in a mates stock N, that had something like 200kw, and I reckon that felt more than enough. Maybe I should just go this route ahhaha. Too many choices.... Planning a trip down south, so wanting to just clean things up and make sure it gets to and from in one piece. Anything else specifically I should do before ? Cheers lads
    • Must be for the car’s lucky charm 🤷🏽‍♂️ She runs fine, but it just seems to take about 1L less. Maybe I’ll have the oil sump dropped at some point to check if there is anything
    • Hmmm interesting. Mine is the exact same and clearly the right one.  The mystery of the engine oil being full after 3.5-4L continues
    • Yes I as well would like to find out where I could get some of the seat material with the red or blue small squares in it
