i see you found its good side to take a pic of.
i didnt realize it had a good side..
You are wrong, it has a shit side and a not so shit side :)
There are a few more pics in my members ride thing, showing how fecked the rear is :)
has anyone here had to have their turbo seals fixed??? if so was it expensive and did it take long to get done??? i couldn't find any info using search so i just asking a general question.
Still running the ceramics? Once you get a price, let me know, too. One of my seals is on the way out, spitting out oil, etc and I'm still running those lovely ceramics!
alright i'll let ya know.. im hoping it's not too much
Turns out my turbo may not be f**ked after all, had a mad mad leak on one side of the manifold because it warped. Turbo feels brand new still and im still gonna get it sussed out by mtq just for curiosity's sake. Im not putting it back on tho...time for an upgrade :D
Edited by Ryanrb25
just watching it as i write this, saw a grey 32 gtr get pulled over for no rear lights, he hell cut sick and said, whatta bout all those rusty shit boxes you dont pull over! cops were fair decent about it in my eyes, he got defected, but in the end a police escort home, and them not charging him for speeding was decent of them! he had 2 weeks to fix the defects! just thought i would share this pointless info to the rest of sau, incase anyone else saw this! imbored yes
Guest
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
