he tried pulling the ill show you my new fuse tomoro, just dont defect me talk, didnt work, he would have got defected and had to spend soooo much money from the look of the mods! sucks that it happens to skylines, or imports, but no tail lights is f*king stupid if you ask me
+10 for playstations customer service
-9 for there faulty disk drive :(
was just about to play some cod4 then my screen went black and my ps3 was making a wierd noise, so i turned it off then on and it wasnt reading disks, rang around and apparently it is a "common" problem with them, so called sony and its already on its way to get fixed
10 business days tho :(
my ps3 broke and did the same thing as yours.
rang sony, they said they will replace the ps3 with a new one in 10 BUSINESS DAYS
nearly 3 MONTHS LATER, i got my new ps3.
and after i asked them to put my old HDD in the new one so i can have all my saved games, they didnt and i had to start over on everything.
sony 'sounded' like they were going to be awsome about it all but it just took way to long to get my new one, i was getting ps3 withdrawles!!!
Edited by Import S13
Yeah they're alright I spose...
HAHAHAHAHAH yeah I miss my old one so bad. I was hoping Aussie would take it out for some skids but so far I think I'm still the only bloke whose drifted one on Mallala, maybe even the only bloke to drive a 100 on there ever :bunny:
LOL @ your thread on jzx100.com too, funny how things change, now I'm the dirty Nissan driver :(
yeah love the 100's gotta be modded tho IMO, stock ones are a little boring to drive.
>>> here <<< is the link to that thread :(
I found mine was a dream to drive stock, so goddam smooth and cruisey (if you like that sorta thing :()
It took me about a month or 2 before I was craving the coilovers to go back in and straight pipes to be fitted :(
My next one will be auto and cruisey, I'm over shitbox cars.
stupid GTT blood test, i ended up throwing up after i had that sugar drink.
probably drank it too fast LOL.
they kept telling me i'll just feel a little sting and i'm like "don't tell me that" lol
but yaaaaaay i can eat again :D
so are you a skyline or not :( :(
steve, how long is the group buy gonna be open for?
i have some pretty big things on my plate atm,
but i dont wanna miss out
um you haven't read 4 WEEKS
lole $134 for rego for me :bunny: low income earner and single parent :P
Guest
    • I would try messing with friction modifier to see if it smooths it out.  Just keep adding more until it stops chattering or grabbing quite so much. If you haven't changed the gear oil in a long time you may as well start there too in case that has anything to do with it. You might want to also verify the initial torque is set to the lowest setting too. Requires popping out one of the CV axles first but that's not too bad. Once you're sure the preload is set to the lowest you can try adding an ounce at a time of friction modifier until it feels right to you.
    • It is possibly 55 degrees for the Nismo version. I had a look through the manual and the stocker has a breakaway torque of 2.5 to 3.5kgm. Supposedly the Nismo LSD goes down to 5kgm when worn in but it is pretty grabby even with very little throttle. Worse when cold. So I guess you have three things. 1. Shims. 2 Friction plates 3. Cams Would think shims would be the easiest but Ive no clue how many tenths of a mm shim thickness change equals how many kgm torque. Also not sure if the Nismo friction plates are similar/different to stock or if they are the most of the source of the diff being angry. Think I can write off the Nismo rebuild kit for the standard diff as not being what I want.
    • Yeah, it was a bit of confusion with me, I rang and asked if they had a boot for a soft top, and then the paint shop when they rang and were asked if it had a hard top on it, which it does, just not a PRHT....LOL Meh, whilst frustrating for all concerned it isn't a war stopper and should be a thing of the past in a week or two In other N/A related news, car is booked in at the end of the month for the cams, springs, retainers, harmonic balancer and retune  I might even pull the lazy arse card and get them to do a full service on it whilst it is there
    • Factory LSD is supposedly a 2 way with a very conservative cam. If you've already tried adding friction modifier to the diff oil and it still locks up too much for your liking you might want to adjust the ramp rate on the cam to be more like OEM instead of reducing initial torque even further. People claim the 8 kgf-m disc kit for the OEM LSD is still very streetable but I've never been able to compare everything side by side on my own.
