SLED: i just filled up with mobile 8000, i like so far, dropped my idle slightly, engine doesn't sound as harsh, seems to drop the revs smoother when i put the clutch in, and just gives what seems like a quiter, yet deeper idle/cursing noise
i think i'll give it a few more tanks, see what economy is like.... BAHAHAHHAHAHA... but thumbs up so far!!! :D
and s2 of californication FTMFW!!!!! how good is it so far?!?!?!?!?!
"no one should ever have to see their own O face"
"did you just touch my ass?" LOL!!!!
Edit: removed partial spoiler
Edited by Fishpaste~
FINALLY ITS BACK ,
was so happy when i saw it was out
btw , did you used to work at adrenalin ?
i would consider switching to Mobil 8000 but in Mobil's wisdom they closed about half of there station's and there's no Mobil's (maybe one) on the way to Melbourne and very few over there didn't see any really
I mix between Mobil 8000 (mostly), Shell Vpower, and BP Ultimate
get down to 15litres left and put 50 in of the next fuel on the list
:D
man these knees are crazy
just wanna hang & thats a teribble way to think
love my kiddies and being stay at home dad to youngest (eldest is yr-R at school), & the little bunny rabbit is becoming a nice companion (follows me a bit, cute)
just so sore, killing me slowly inside & out
start SR morphine patches tomorrow
on the good side, the Stagea looks pretty nice with the $110ea 17x7.5 +38 BJR Graphic mags. lowered another 2 circlips front and rear to 360/345mm
Guest
    • It is not a dual mass flywheel, so you will get some gear noise on a BNR34 unless you deviate from the OEM fluid spec and run a thick gear oil like what Nismo recommended for a while. Unfortunately I have never weighed the flywheel by itself prior to installation but it is not that light. It's probably an 8-9 kg flywheel. OEM BNR34 dual mass flywheel is like 14 kg which is kind of hilariously heavy.
    • Got around to installing the Tomei Cam Cap Studs and the Hypertune cam baffles/splash guards. Unfortunately, I was not aware that the cam cap studs do not clear the stock RB25 internal cam cover baffles. Some research found a set from boostdoc which includes a replacement cam cover baffle and full length cam baffle + tools and fasteners. but I'm not keen on re-buying what I have already bought. So the plan is to take the hard route and modify the existing cam cover baffles to clear both the cam cap studs and the hypertune cam baffle plate. I assume there must be people who have gone through this even just to convert from cam cap bolts to cam cap studs? If so any tips would be appreciated. Otherwise I think I will mark where the cam cap studs foul, drill clearance holes in the cam cover baffle, and remove the cam cover baffle oil returns to clear the  hypertune baffle plate. I will also need to remove the baffle and drill and tap threads to bolt it back on so i can clean out any swarf. Fuel tank foam as extra cam cover baffling?
    • The incoming weather event seems to be affecting people in weird ways....🤣 And no, whilst there is some fancy engineering going on, I have no real interest in anything rotary really I had a Capella in the 90's, the rotary engine is way to temperamental, and extremely thirsty for my liking  If I won lotto and wanted to waste a ton of cash, a boosted K-swap would be what I would look at, until then, the N/A MZR2.5 will be at home in the engine bay of the NC A build like this, just without the idiotic street pulls and skids would be interesting to waste a huge amount of money on https://youtu.be/EgqAoVtUD1E?si=n3_umivrUPP8C9Cs
    • Now we're getting somewhere. All we need is a fractional rotor system so we can also have the RX3 and 5 back, and the world will be right again.
    • With that engine being a one rotor, would that make this into an RX4?
