Ruby i will be done like a clown. I was supposed to do one this month but fate stood in the way!
I'm going to hit the website tonite (phillipislandridedays) and look up a date that would suit me and my studies. A friday is always better for me as the mondays are just too hectic to get back to Adelaide. At least Friday you can take your time returning over the weekend. I'm keen for a February time slot as the weather is better at the Island and winds are low. So at the moment, I'm aiming for a Friday mid February 2009.
No house or accommodation organised yet, but I've got mates over there who might join me for the day and we'll shack up somewhere ;) They mostly get out in the B2 group and me and a few others in B1. I might consider B2 considering the length of time since my last stint, and the fact I'm recovering from injury.
BTW take a ride out to lala tomorrow and watch me do my thing :banana:
Edited by RubyRS4
God damn frigging GRRRRRRRRRR got stranded on holbrooks rd near henley beach rd for the past hour and a half coz an intercooler pipe came off waited around for RAA to bring a socket set lol think I'll invest in a small socket set to keep in the car....
just dont do what i did and get one of those $70 repco (my first toolkits) i had and have lost or broken all the important bits
i have to go to the hospital's birthing assessment building 2moro coz i've been really dizzy and even at times
had blurred vision, and now having these horrible pains. hoping it's nothing bad
all the best with the result tomorrow Amanda.....no point in stressing out until you hear from the Doc
yea good tools aren't cheap, i lashed out 5 hungy today on whats not even third of a tool kit yet....well worth getting quality tho.
Edited by Ryanrb25
Guest
    • Or get a guy in his early fiftys to do it. A single good "oof" and about two cracks from his lower back is about the right tightness...
    • It's impossible to convey what it will feel like to get the right torque. But you can develop a feel for it. A 900mm breaker bar is.....f**king huge. I only use a normal ~400mm one. But with 900mm being very nearly a metre, and the right torque being in the order of 100Nm, then you're going to need a bit over 100N of force, which is about 10 kg. So if you practice using the bar pulling up, instead of pushing down, then it will be about the same effort as lifting a 10kg bucket of water. That's what the pressure against your fingers should feel like. Ish. If you use a more typical length breaker, then it's about twice that. So a good 20 litre bucket, or a little bit more.
    • Also, if anyone has a torque wrench around Williams Landing area and can lend it to me for like 5 mins - I got 4 bottles of Furphy left and I’ll throw that in with a Happy meal 😂
    • So today I decided to bleed my brake fluid, which meant to the wheels came off the car at my garage for the first time. I only had a 90cm breaker bar with me and I noticed that some 1 or 2 lug nuts were a bit hard to get loose (from when the shop did the coilovers) Now.... when it came to putting them back on, I didn't want to put all my weight and overtighten them. So I hand tightened as much as possible and then put normal pressure on the edge of the breaker bar and tightened it until I couldn't turn it anymore without putting in an effort. Do you think that is tight enough? Or is that still too tight?  They are tighter than finger tight. Last thing I want is to have them strip or warp sh*t. But hard times mean I can't just go down to Supercheap and get a torque wrench 🥺
    • Dunno what to tell you, when I look at it on Consult I can see this warmup timing map kicking in around 40C coolant temp and it sticks around for a while:  At part throttle on the normal base timing map it peaks around ~43 degrees of timing or something like that, this warmup timing map drops it to like 12-15 degrees.
