The Sa Wasteland
Cubes
 Share
wait your turn balfours kid lol
haha nice 1 BITCH
hmmmmmmmm no plenum n boost controller 4 u then...lol
this may sound gross but my job is actually fingering donut holes with chocolate icing and i no how 2 2 put the holes in aswell...lol
haha nice 1 BITCH
sounds enticing :) i think ill stick to vilis from now on hahahaha, sorry dan ;) can you share the real ingredients of meat pies also, im guessing theres lots of :P in there but not much else hahaha
sounds enticing :D i think ill stick to vilis from now on hahahaha, sorry dan :O can you share the real ingredients of meat pies also, im guessing theres lots of :( in there but not much else hahaha
man those balfours square pies used to be bloody nice until balfours family sold the business.... nowadays I bite into one and it just tastes like gristle and salt... last time I had one, i took a bite and gave it to the dog.... once u go villies, u never go back ;P
-D
Once everything's fitted, throw up a photo Ruby!
Are you happy with the sound of the muffler?
Yep. Together with the Lukey resonator, its a nice sounding system ... without upsetting the police :)
You can really hear how tough it is on boost tho :)
I'll take pics tonite if I can temp fit the lip. I'll do a proper job on the weekend, and will wash the dirty bitch and take better pics :banana:
Thats exactly what i had before i got my exhaust redone (before i sold it to ya).
Its nice and calm sounding down low in the revs. As revs go up its not extremely loud but a very nice sounding scream :banana:
Guest
 Share
    • There is a LOT of stuff that can be done, it all depends on how much time and money you want to spend on doing in.  Not all ECUs will be able to do it, and the more control you need the more time and knowledge needs to be put into making it work.  If you're willing to spend the time and money and have the right hardware and skills involved there's a lot that can be done.
    • I am impressed with all this level of adjustment. I didn't expect all this possibility
    • Correct.  In the case of the 500kw dyno plot I showed you the car actually runs two boost control solenoids for boost control and a 5psi wastegate spring.  It allows me to control how much boost pressure is applied to both sides of the wastegate valve at any point and fairly accurately control boost target as a result. I've tuned it so that it's able to target anywhere from 5psi to 25psi depending on what's needed.  The target tables I've set up in that car are Gear vs RPM, so every gear has potential for a different boost (and torque) curve.   First and second gear have quite low boost targets, third gear actually has different target boost all the way through the rpm range as it's a stock RB25 gearbox - the boost targets have been chosen to maintain a peak of 600nm (what the owner has set as the maximum torque he's happy with putting through the stock 3rd gear) but it carries that to the rev limiter.   The boost curve to achieve that is something of a ramp up, then hold, then ramp up again and the power curve looks more like a flat line haha.
    • so you can decrease or increase the boost depending on the diet as you wish?     by acting on the wastegate?
    • That's torque and power, it's all from a single run.  The boost curve is "held back" from it's peak target in the 3500rpm to 5000rpm range from memory, so it ramps hard to something like 18psi then climbs more progressively to 23psi nearer 5000rpm.   It makes the torque (and power) ramp more "natural" and less hard on parts and traction, it doesn't feel artificially held back.
