tempted to drive the 'line to adelaide... might as well destroy the front bumper before the new paint and bodykit. hell the kit's coming from Viva garage, I might even be able to put it on the car while I'm there :(
Ok, my times might be a little bit off - (i do start out towards the North), but Whereis.com guves a time of 1:44 from the city and its times are very conservative.
Roseworthy to Clair is 1hr by Whereis.com (again quite conservative)
And in both cases you are into the wineries befor you get to Clair
2:20 am :blink:
Just got woken up by my car alarm going nuts! Went n invesigated but nothing, checkd my doors n stuff but no damage, so now im gonna sit awake all paranoid lol.
Takes a bit for my alarm to go off, its not that sensitive so couldnt have been a cat/wind etc.
would be a bit hard to steal it anyway, would have to move the car behind it and get past locked gates..
Must be something in the air tonight Flick. :blink:
I got woken up 20 mins ago by 3 cars overturning all the wheelie bins up our street. :blink:
Got some rego numbers and gave em to cops so they should get a visit soon.......lead car was defected too!!
mmm I've seen it, just off Rundle st right? yeah might make a booking with them.
Yep that's the one funky.Not too badly priced and a variety of cars and close!
tempted to drive the 'line to adelaide... might as well destroy the front bumper before the new paint and bodykit. hell the kit's coming from Viva garage, I might even be able to put it on the car while I'm there :blink:
Yeah do it...I use to do the drive Sydney to Adelaide and vice versa and the stone chips weren't that bad..
I really want to do it this year miss driving the adelaide hills!! :)
P.s Peeps more then likely coming to SA in March and April..
hahaha good work super sleuth, i hate people some times
Dam your up early!!
Morning Peeps :blink:
come here with an old bodykit, home with a brand new one
i got a nismo key today :)
exhaust tomorrow yay
yay rhymes with gay :blink:
well... front bumper, sides, rear, front guard, rear guard, and bonnet. I'll only drive if the cost of driving adds up to less than the cost of hire car + freight of kit to our workshop + flight to adelaide.
plus i gotta try and sell a standard r32 gtst bonnet in adelaide or figure out how to take two home.
2:20 am :D
my old 34 did that. The alarm drained the battery. Might be the same thing happenin to u ??
lol morn Jess hifive
Luke you got me thinking why would you buy a $900 exhaust when you plan on making it a turbo :thumbsup:
Andz dont be mean, it will bite you back one day :/
Im going turbo cat back exhaust, so i dont have to change it again when i go rb2630. Got a brand new HKS hi-power exhaust for $684 delivered :P now just off to exhaust tech tomorrow for de-cat and a new flange to fit it.
Guest
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
