wow wish i could quit mine!
do it!!!!
nothing like a little peer pressure, I've been getting it on my phone from a few influential people
don't do it unless you have somewhere else to work
have to say i'm getting the "am i doing the right thing?" feeling now
ah what size is it
I think something like a 3inch pipe with a 4-4.5inch tip. havent really mesured yet. all stainless to.
Hope i get it all done tomorrow, wouldnt mind hearing how it is in the tunnels hehe
Hey Pete its ceramic and after 5,000 rpm it sounds like a supercharger whistle so now I'm not boosting @ all and I've taken as much boost out of the manual controller as i can so its basically running factory boost to which i'm not using trying to drive on 0 or neg vacuum
Sounds like you've lost a little bit of the impellar which probably just shot out of the exhaust.
I wouldn't be doing too much driving if I were you because the blades can get fairly unbalanced and shatter now.
OK if the pieces shoot straight out your exhaust.......not OK if a piece gets caught between an exhaust valve and seat.
oh what happens then and when I'm on negative vacuum my understanding is the turbine isn't spinning?? :(
Wouldn't have thought it would stop spinning altogether but as long as your under boost I can't imagine the thing would fly apart.
You would think that the ceramic has gone but you never know, it could also be something else?!
My old 32 was doing this about a day before the rear tubine let go and lodged itself in my cat, as SLED said i really wouldn't wanna drive the car that much cause it sounds like the turbo's close to death
yeah I'm doing barest minimum with 0 or little boost
when mine blew i was in town and had to drive my car to woodcroft to my mates to fix it, was a f__ked drive with no boost trying to get up south road
Guest
    • I would like more noise related info for my truly uneducated guess  Does it do it at idle or when revving, clutch engaged, and disengaged? Does it only do it when the car is moving? I've heard "similar" noises from a clutch pack that left the chat room, and CV joints that have chewed themselves out But as Matt said, how's the yokes, tailshaft and centre bearing going after their last little issue Fingers crossed it is something simple  Weird noises make me cringe
    • One other question, is there a chance that changing the idle speed can lead you down a rabbit hole and is the reason the tuner didn't touch it? Reason I ask is because if that's the reason the tuner avoided it then I probably shouldn't be touching it lol.
    • Pfft. As if I'd ever point a high pressure washer at my car.
    • The nature of my commute has changed. Way back then it was traffic lights all the way, for ~28km. It sucked. When they finally stitched the expressway together I could do a good 15+km of it at a steady 80-100 with no stopping. That alone has gotten me down to flat 10s. Prior to that it was mid-high 10s. I can't remember the delta that I saw when I got the idle down. It was only ~150 rpm, because the idle speed was never terrible, but for the delta in consumption to be noticeable it would have had to have been at least 0.2-0.3 L/100km - which is not to be sneezed at when it comes for absolute free. It's only about 50L per year, but that's ~$100. A few extra pizzas is always welcome. Note that I have a record of every tank of fuel that has ever gone through my car except for a handful put in by someone else, like my mechanic. I can show you the difference between stock RB20 and tuned RB20, stock RB5Neo and tuned, winter and summer fuel blends, winter and summer fuel blends when the ambient temperature is not appropriate for the blend, working O2 sensor, blown O2 sensor, boosting f**k out of it and frightened to boost it because it is pinging, and so on. OK, I probably can't do all that now with 100% clarity - but at the time when any of those things were in event, you could see it in the records. There's 25+ years of simple tank after tank records, so you have to look for landmarks to work out approximately how old any single record is. What's really important is the meta data and that lives in my head.
    • If you're claiming the issues are not skyline specific, then either the USA is living in the 90s / early 2000s, OR you have the issue of "survivor bias". Which is you're mainly hearing and listening to those with terrible experiences, and haven't found the guys who have cars with good decent builds and no problems. It happens in AU too, that plenty of people keep having issues, and they keep going to the workshops that are known to be shit "because I read on the internet". Even worse, are those who keep posting on the internet as though they know for a fact what something is, when they've never touched/looked at said item in their life, and again are making assumptions, based on something they read, or because it's a certain way in other cars. It's even funnier when those same people debate the facts with the people who've lived and breathed this stuff for over 15 years. Example, I've had someone tell me you can't do something with a Skyline, because they read it on the internet, except I can tell they're wrong, as I did that exact thing back in 2008 with my Skyline.
