Thats a bummer.....hope you didn't have too many troubles buddy.
Did you eventually see what the problem was with the old one?
na the old one is still on my car
Good day eh Steve? Bet you are itching to get that new turbo fitted!!!
yeah :) cheers heaps for your help will get it fitted Tuesday evening :D, will sort out a time for me and shannon to get the fuel pump in my car also dont need it detonating on my way to melb
better leave a trader rating for you :P
ive asked this question elsewhere, but to no avail. Need some advice from anyone running an RB20DET, and using an aftermarket oil pressure gauge.
finally got my oil pressure gauge in on the 31. Did an oil change while i was at it (naughty me, 2 practices on the same oil and she's black as hell). Admittedly i changed my grades of oil (as i had some sitting around from drift school) - gone from a 10w30 to a 20w50...........wouldnt have thought that would make THAT much difference tho
started it up, pressure started at 30psi..........after about 30sec i hear a warning beeper going...........look into the cabin and see the gauge at 2psi.........turned it off, checked under the car (no leaks etc, nothing wrong). Started it again (mind u, its running EXACTLY like it always has), back at 30psi, and after about 15sec the oil pressure is dropping off back to 2psi again
im confused. is my gauge knackered (its brand new), is my sender knackered? I know it couldnt be a true reading as for that low a pressure the thing wouldnt be turning over. There aint no death rattle, nothing like that. Wont get a "legal" chance to take her for a drive on the street till at least next Monday, so wont know how it behaves under load until then.
any advice/feedback is appreciated
fk i hate it when im the office scape goat.. i organise stuff... the ppl involved don't communicate, then i wear the fall out when the customer shows up and the sales tard turns around to me all like wtf where is the techo??
sales guys sh*t dont stink, and they have no honour...
techo's are delicate genius' needing everyone to tip-toe thru the tulips. and feign not understanding things if its 1/2 way laymans terms...
and both only pay attention to procedures when it suits them.
/rant over.
i feel better now
never a truer word spoken! i'm just being a bit picky atm thats all, have blanketed the job market wif my name, had a few offers but they weren't up to par. What i am working towards is joining the defence force, the corporate environment is not for me... been thrashing myself into a resemblance of fitness :P
up hill battle but im getting there
/rant over.
i feel better now
hmmm that sounds familiar...... hence the fact i quit last week
nos only last so long and nos will still blow your engine
meh. have u seen high octane? they did an experiment on an r31 to see whether they could blow the engine with nos took a high amount of hp before it blew.......................was quite funny tho lol
i dont even keep the bottle in the car so its all ok............. im not that stupid. its for dyno and track use only.
have been told tho i can get defected for the lines *touches wood* hope it never happens tho.
Better off turbo'ing it..
Voids the insurance exactly the same but at least you may get away with it as the cars are released with turbo if your ever pulled over. + then you can use it all the time. :(
Even still a ~100hp nos is bugger all; you'll still have a stock rb25det with a pfc sit side by side if not whoop yo ass. :D
150hp you may pull away but very slowly.
We don't have a track nos can be used at. ;) One day AIR will reopen for drags.
but why should i be like every one else who has a turbo'ed car? honestly what ever happened to uniqueness??? i dont want to be like every else.
and im sure if i ever take on a stock GTT i would be able to keep up i too have a power fc. i have many plans for my car, and none of them include a turbo.
and what about mallala?
Guest
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
