yeh ill get a set!
also how do i measure to modify my tailshaft?
i need to know so i can take it to a place to get modified to fit the rb25 with 25 box on 32!!
cheers in advance!
try using a tape measure......???
ahaha
So how many ppl are after splitfires here? might try and talk to some sponsors and try and get a better deal if we get like 6 sets of them.
+1 for a set of splitfires.
i've been meaning to buy some for a while now. My std coils are toasted!
also posted in the you tube thread
pure nissan genius
good find!
adrian, youll have to wait till tuesday mate, it needs the crossmember and you need to measure from a certain part of the centre bearing and front yoke because there is free play in the front yoke, unless someone can help him?
Edited by Ryanrb25
just sent a pm to access autoworks. Trying to get them cheaper then 520del at the moment, but thats still a good price as the yen is like 65 atm :O:)
i just got mine for 510 delivered from a mate from qld, if we can get numbers ill ask him if he can get it any cheaper for u guys delivered =]
did they win?
3-0 in the first leg of the semi-final of the Asian Champions League. Their opposition - Uzbekistan's Kuruvchi (Bunyodkor) - have almost limitless funding to buy players. Rivaldo is earning US$7 million a year with them, whereas Adelaide United have a salary cap of AUD$1.9 million + whatever money is being wasted on Paul Agostino.
A pretty good effort and Hindmarsh stadium was rocking.
Edited by writeoff
spent the last 3 or so hours washing, clay barring, and putting a few coats of wax on the celsior, still needs a polish and a buff, but f**k, paint looks like glass, dont think it was even that clean when it rolled off the showroom floor.
Ill have to keep my eye out for it round the corner now :D
my rc drift car looks almost the same as my real car except the rims
was even painted by doyles the same who did my car :blink:
would be down for a sau rc drift day!
Hell yeah im down! shoved some camber into the front and rear, and a bit of toe in, handles much better
Guest
    • Dang. I love the little 'oil used' bingo card on the side.   🤣  Well, now they can use a box and an oil-filled goon.
    • Many many moons ago, I was chatting with Andy Wyatt, about his auto ignition tuning. One of the HUGE things he said to me, when tuning for power, right where you hit peak ignition timing for your max torque, dramatically increases NOx emissions. He was finding in testing, particularly on engines you could advance timing beyond peak torque, that backing the ignition timing off a couple of degrees only made for a small drop in torque (compared to if you keep backing it off further the same amount of degrees) but dramatically reduced NOx emissions. I'd say targetting for 14.7, and he's even mentioned in some scenarios going slightly leaner, and pulling a few degrees of IGN timing will help pass for emissions quite a lot. However, who tunes an RB for emissions
    • The main stuff from.Vibrant I see is more their intercooler piping, and everyone raving about their clamps, but when I looked it was about $150 per clamp... I was a bit   I also thought the public price SP had up was high. As Mark said, a normal exhaust shop can fab them. It was many years ago that I had a full exhaust built, but for a full turbo back exhaust, and 2 custom built mufflers, plus a high flow cat, was about $1,100, and that was fully installed, drive in, drive out. I believe SP was about $900 for 2 mufflers, just supplied   These days, I just buy the material and built it myself, because I need to stretch my $$$
    • I'm pretty sure if it's considered a gasoline powered vehicle you have to do certification against a fixed, very expensive certification fuel.  If you add two precats and then replace the main cat with two cats back to back you can get an RB26 to do 0.24 g/mi HC, 1.6 g/mi CO, and 0.3 g/mi NOx on the FTP-75 drive cycle. Found this out courtesy of California's laws at great expense. Divide by 1.61 to get g/km. So even with extra cats + precats you're blowing past the NOx limit by probably 2.3x. Probably the only way to get an RB25 or RB26 to meet euro 4 purely from an emissions per km standpoint and not durability/OBD2 requirements is retrofit at least intake side VVT, clearance the pistons to allow the full 50 degrees of advance so part throttle EGR can be maximized, and change the wastegate control from conventional 7 psi spring for example to one that is always fully open if the wastegate line is at 1 atm or higher and only close it in response to vacuum. See BMW's N54 engine as a reference for how this works. You would need to find space for a vacuum tank to function as an accumulator in this system. That way you can avoid any heat loss to the turbine as much as possible during cold start to heat the catalyst faster. Then find some way to eliminate as much as possible cold start enrichment to light off the catalyst rapidly. Maybe secondary air injection if there's no way to avoid cold start enrichment. Close coupled catalysts in the downpipe are probably necessary. I would also probably swap to EV14s, pick something with the correct spray targeting + dual cone pattern for the intake manifold you're using. EV1 style injectors to pass anything resembling modern emissions requires a very annoying air assisted injector system to break up the droplets at part throttle/idle which still doesn't work that great compared to just having smaller droplets from the injector to begin with. Realistically, you're probably going to be financially ahead if you just pay the fines instead. Or don't drive it into the city center. There's a reason why Nissan never bothered to even attempt certifying an RB for CA/US emissions. The VG30 needed external EGR on top of NVCS to pass in the 90s. Doing all of this work is also distinctly expensive and you're going to struggle to find anyone who is remotely interested in helping.
    • I remember those, people use to steal them to make bongs.....
