well lucky it wasn't! but the car is black with some club sticker on the back and 19"+ chromies with a custom number plate! and plus his car was loud as a mofo
I would of just ignored the commo :) might of been an undercover... too risky... damn new commodores lol
yeh my mate in the gold CV8Z monaro said he saw every1 scatter...lol
i cracked up laughing when he told me n i thought 2 myself "i bet that was craig's organised cruise"
dob on u 4 wat?????????????????????
hey was it u that had a mate with a vxss??? was it gold??
na i dont have a mate with a vx ss, i have one with a worked vx berlina though, me and him where dead equal
everytime we had a go (on private road) even though i had mass wheelspin through 1st 2nd....
cant wait to see your car on the road again man, it porn!
yeah sorry about that Carl............you should see me on a bad day :D
hahaha, its all good, 99% of the time its water off a ducks back with angry ppl. in my last role i was a TL for 13 engineers that work with secure coms (VPN's and hardware firewalls)... all i used to deal with was escalations, so i have a really good grounding in conflict resolution.
one thing that always gets me on the front foot is when someone that starts a conversation/query with "listen...", i find that quite rude. (this is not meant to offend but i find 99% of the ppl that say this are of a common nationality/background)
Bezender.. Get in to a company where you can work your way up and get away from being a CSO.
Internode is a good example. Admittedly you may take a pay cut from telstra/optus for the first couple of years but after 1year 2 absolutely max if your your not all that keen and your up and away from front line support.
i have put my resume in to move to there and take a $18k paycut... the money does not phase me, i'd rather have satisfaction. gotta keep slogging away with my mcse and ccna in the mean time
^ hey Ryan you/your place of business can retune stock ecus yeah?
My car is out of tune since I swapped the exhaust and wondering what sort of rough price I'd be looking at to get it touched up. It has already had all the stuff put in to be able to tune, so should hopefully only need a few hours to rectify a/f ratios, it's fking eating fuel big time at the mo :rofl:
Guest
    • Lucky man, who owns it in the family? Any pics?
    • The engine stuff is Greg Autism to the Max. I contacted Tony Mamo previously from AFR who went off to make his own company to further refine AFR heads. He is a wizard in US LS world. Pretty much the best person on earth who will sell you things he's done weird wizard magic to. The cam spec is not too different. I have a 232/234 .600/603 lift, 114LSA cam currently. The new one is 227/233 .638 .634. The 1.8 ratio roller rockers will effectively push this cam into the ~.670 range. These also get Mamo'ified to be drilled out and tapped to use a 10mm bolt over an 8mm for better stability. This is what lead to the cam being specced. The plan is to run it to 6800. (6600 currently). The Johnson lifters are to maintain proper lift at heavy use which is something the LS7's supposedly fail at and lose a bit of pressure, robbing you of lift at higher RPM. Hollow stem valves for better, well everything, Valve train control. I dunno. Hollow is better. The valves are also not on a standard valve angle. Compression ratio is going from 10.6 to 11.3. The cam is smaller, but also not really... The cam was specced when I generated a chart where I counted the frames of a lap video I had and noted how much of the time in % I spent at what RPM while on track at Sandown. The current cam/heads are a bit mismatched, the standard LS1 heads are the restriction to power, which is why everyone CNC's them to get a pretty solid improvement. Most of the difference between LS1->LS2->LS3 is really just better stock heads. The current cam is falling over about 600rpm earlier than it 'should' given the rest of my current setup. CNC'ing heads closes the gap with regards to heads. Aftermarket heads eliminate the gap and go further. The MMS heads go even further than that, and the heads I have in the box could quite easily be bolted to a 7.0 427ci or 454 and not be any restriction at all. Tony Mamo previously worked with AFR, designed new heads from scratch then eventually founded his own business. There he takes the AFR items and performs further wizardry, CNC'ing them and then manually porting the result. He also ports the FAST102 composite manifold: Before and after There's also an improved racing crank scraper and windage tray. Helps to keep oil in the pan. Supposedly gains 2% power. Tony also ports Melling oil pumps, so you get more oil pressure down low at idle, and the same as what you want up top thanks to a suitable relief spring. There's also the timing chain kit with a Torrington bearing to make sure the cam doesn't have any thrust. Yes I'll post a before and after when it all eventually goes together. It'll probably make 2kw more than a setup that would be $15,000 cheaper :p
    • Because the cars wheels are on blocks, you slide under the car.   Pretty much all the bolts you touched should have been put in, but not fully torque up.   Back them off a turn or two, and then tighten them up from under the car with the wheels sitting on the blocks holding car up in the air.
    • Yes. Imagine you have the car on the ground, and you mine away all the ground under and around it, except for the area directly under each individual wheel. That's exactly how it'd look, except the ground will be what ever you make the bit under each wheel from
    • Yes, if you set the "height" right so that it's basically where it would be when sitting on the wheel. It's actually exactly how I tighten bolts that need to be done that way. However....urethane bushes do NOT need to be done that way. The bush slides on both the inner and outer. It's only rubber bushes that are bonded to the outer that need to be clamped to the crush tube in the "home" position. And my car is so full of sphericals now that I have very few that I need to do properly and I sometimes forget and have to go back and fix it afterwards!
