for sure Dan; you ignore just about any price you'd see on the piece of paper hanging in the window of a car at a car yard.
jeez i remember the price listed in the window of my white 33 (in my avatar) when i bought it from a yard back in the day... we knocked quite a sum of that price off compared to what i paid :)
guys need ya help palease :)
oka so went to go see my car today down at premier paint n panel n its finally coming together..yay..but a lil problem has occured..they have gotten my car to start and god does it sound good to finally here it again lol but now my hicas light is on and the steering is heavy as...ive had the hicas light on before but the steering wasnt affected..all i did was change the power steering fluid and it went away.
the guy said that had to disconnect some hoses around the power steering pump to do some work so im hoping that it just needs a top up of some fluid
would i be right??? or is it something else??
there hoping to have my car finished by this friday....cant wait :)
ur help will be appreciated.thanks
you will prob find that due to the car sitting around for so long, all the fluid has drained from the lines, and dried up.
give it another change, and see how you go :)
good to hear its nearly done...
This might not be the issue, but my Hicas light was on a while back and the steering was really heavy. It turned out to be a loose battery terminal (no bullshit). New terminal and the issue went away.
Check that, but more than likely it won't be that.
But check the power steering fluid and the hose connections.
Last night after work i decided to go to town on my dump pipes with a die grinder. Where the 2 pipes join together i ground out the hole to perfectly match the shape of the smaller pipe, spent about 1 hour on them as they are stainless so had to try and keep the metal cool. It should help to improve exhaust flow a fair bit :wacko:
hmm, how are b pillars stuck on? (The black plastic that is between the front and rear side windows) just glue?
On 33's theres a couple of lugs behind there, just pull the bottom out gently until it unclips (you may need a flathead) then lift it upwards. I've never tried doing it on a 34 so it might be different.
went and had my car remapped at turbo tune today and i gained 34 rwkw out of it
first run pulled 88.1 rwkw with a blocked fuel filter and fooked fuel pump..so replaced both of them and it pulled 111.2 rwkw
then after the remap it pulled 122.2rwkw..
im pretty happy with it considering the only mods are HD clutch, 2.5" full exhaust system with race cat and K&N panel filter
Guest
    • But if you've got the flex sensor whats the issue? You just run what you can get your hands on.  I can't see any reason not to run e85 if it's relatively local to where you live.
    • Exhaust end of this month, and then tune after that whenever there is availability. Still tossing up between a pure 98 tune or a flex 98/e85 combo.  The (lack of) milage in e85 isnt great. Start to get anxiety if i go for a long drive and there arent any united servo's nearby
    • I mean I can be OCD'y but this is really over the top. At that point why not just run a full wideband fuel controller? Especially if you run 3 widebands. The system works pretty well, which is trimming low load stuff to be within a few percent of the base map. Pre-engine _change_ the base map was only 1-2% off, depending on ambient temp, elevation, etc. Under load the LS is really very straightforward to tune, enough that a wideband closed loop would be overkill. If I really cared (and I hope I don't) I can always just go back to the MAF system the car actually came with. Which does all those nice calculations for me (temp, altitude, etc), now that you can buy 102mm MAF's that do not cause restrictions.
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
