LOL once a poser always a poser hey matty :laugh:
Good to catch up again
for sure mate
and yeah, thats true...........wasnt quite game enough to hit rundle or hindley on the way thru, but squeezed in a bay lap.....
perfect weather to as well, lotsa cars so a bit of stop start. when i got a bit of an opening to giv it a lil bit, it'd built enough fuel up to giv a nice pop (which was rather loud ricochetting off the buildings LOL)
:glare:
Would i be better off getting 17x9 front 17x9.5 rear (need to roll the guards though at the back ?) if i dont want to use spacers ? How would that fit do you know...
The width is one thing BUT offset is another, If Matty has had to use spacers then i would assume you will need to also!!
Matty did have the 9.5's on the rear which sat very similar. I think he changed them to 9s because he wanted to go drifting more often, he got 2 pairs of 9s as another pair of 9.5's weren't available, and he can put slightly skinnier tyres on the 9's (easier to spin up?)
Anyway, im sure he'll anser soon :P
Were spacers used when he had the 9.5's on the back ?
8s on front yeah, not 9s LOL. And thats rite, never ran a spacer on the rear with the 9.5s
9.5s are +18 (gtr offset)
9s are +35 (s13, r32 etc)
currently running a 25mm bolt on at rear, goin to put the 25mm up front tho, and get a 35mm for the rear to push them out more
ran 235s on 9.5s (was a bit hard with 155rwkw to spin 3rd), but now run 215s on 9s (and it spins easy as)
to put 9.5s on the rear of the 31, it required a bit of massaging of the guards
and scandyflick..........that was the plan all along. 2 red 31s.......one mild, one wild.....................
Hmm i really want the car to grip well. So what width would you recommend for mine ? (keep in mind i dont particularly like spacers...but i dont like my rims sitting inside the guards either :P)
how much power u going to be making? thats the question
id probably say try and get hold of some 9.5s for the rear
*edit: my idea just blew thru LOL
Edited by Matty 31
i thought you were getting ben's roh's?
plans always change with him
just spoke to him, he's managed to make them fit on the rear LOL.........and by the sounds of it (20lb hammer) he's got them to fit ............ when the rear coilovers hav no downward adjustment left in them its got to be low LOL
Guest
    • So we have most the interior back in, and for the first time with one OEM speaker hooked up. The 31 is running, driving and now tunes!!! Hahaha yet another step for the sub that sat 10m under for two weeks!!! unbelievable really 👌 lots of love work and not giving up on her. Seen so many youngsters part way less, and in way better condition. I’m stubborn, thinking another problem is just a hurdle to overcome, One at a time. IMG_9277.mov
    • That is correct. I'm using a modified ABS ring and a ZF speed sensor on my rear diff for speed input. I'm running a Haltech ecu.
    • Been busy with the newborn. We originally thought we were going to go for a third, but we're good with two lol. He's starting to actually sleep now so I've had some energy to work on the car. It's been parked away in the garage since late November due to winter.  I went ahead and redid all my head oil drains. I originally had my front and rear head drain going into the same pipe but have since split them up. I also added an Ethanol content sensor to get ready to run E85 this summer. Tossed it on my return line. Sensor sits nicely under my intake manifold.    I also have a lot of parts that came in for my rear end. I'll be swapping over to a 3.3 final drive and doing the GK teck anti squat mod. While the rear subframe is off, I'll also change every bushing. We're planning on buying another house soon with the condition that I get at a minimum a 2 door garage, so I'll wait to have more room for this. Now onto the strange things that recently happened... After changing the lower rad hose (It had been sitting in my cabinet for well over a year and was the last hose I had to replace), I let the car idle in the garage to bleed my coolant. After running for a few minutes, it started missing. Got much worst within a minute or two and then stalled and would not restart. My crank sensor decided to crap itself. No damage, no explanation, just died. I went ahead and replaced it with another ZF sensor but the heavier duty stainless model with a shield. Tossed that in and started right up. Has anyone else seen this? I hate when things fail without cause. Luckily this was a blessing in disguise... This lead me to recheck my timing. It seems I may have had a beer or two the last time I had set my TDC angle as I was off exactly 5 degrees... I miscounted a line haha. I was running 5 degrees less then commanded. It's a little embarrassing but helps explain why my dyno operator seemed to think I should be making more then 478rwkws.
    • Sharing results from recent Liberty Walk R35 GTR, since they are still considered as somesort of a V36 Skyline. We do them turbos too. This are high flowed SS-1 models with ball bearing conversion done.  Car have managed to pull 485awkws @ 20Psi so far pushing limitations of factory built engine. The build list for R35 GTR enthusiasts as follow : HyperGear high flowed stock turbos in SS1 (G25-660 specs) Custom titanium intake pipes. Vspec performance titanium front pipes. Vspec performance 4" titanium exhaust. Upgrade fuel pumps. 1200cc injectors. Ignition coilpacks Hks intake plenum. Hks intercooler piping. Greddy intercooler. Greddy bovs. Top-secret coolant reservoir. Emtron ecu. Straight E85. Built gear box.
    • Nah no bearings, just slip fit.  Would be a reasonably challenging but not impossible job to modify it to run bearings but I'm hoping that's not necessary as I may have well built one myself if I end up spending hours modifying it!
