It just didn't squeel cos I'm awesome Craig :(
Seriously though that stuff helps, and also chamferring the sides of the pad with a file. Do both and follow proper bed in instructions and you have no worries
Well that depends on how cheap you want to sell it for :D
i wouldnt thats the thing. its mcf**ked. even though id sell it as that, i wouldnt want to do that
Aww your selling it!! :D But you just got the Car trailer!! :(
im re-shelling jess...........this chassis is buggered. Put 4 axle stands under her and the chassis only sits on 3
plus im stepping it up a bit. While i hav the chance, its getting cage, seam welding, coils, better wheels, and a bit more power (in the form of a TD06)
just want to mention, if your organising an sau event, please put one post in the SAU Calendar thread in the stickies:
put the date, and the title, then the link underneath, eg:
"27/10/2008: Tupperware Party
www.skylinesaustralia.com/forums/omgimorganisingatupperwarepartybro.html"
how the hell do i make my Non Available power skyline sound decent and don't say turbo because ive already been through that tonight
its hard to explain the shit noise it makes , just sounds shit .
idles nice , soon as you touch the accelerator , BAM ! shit sound kicks in
Solution for NA noise making goodness.
Individual throttle bodies with velocity stacks infront of them and nothing else
Ridiculously large cams
Proper tuned length extractors and a well sized exhaust
lightest flywheel you can get
= snappy as fuck, crisp, angry sounding NA, that will still get raped by mildly worked turbos, but sound about a million times better doing it.
In all seriousness, I wouldn't bother hey :)
new exhaust dude, simple.
yer i know but i have nfi wtf to get :(
dont put a homo cheap ass cannon on it, 2.5 cat back system with a good quality rear muffler with tip/s of your choice.... should have you car sounding nothing like auto non turbo supra boat in no time :)
cheap cannon is what the previous owner put in it , welded it on to the stock system iirc , so yeah sounds like cock
i can get a jun bl muffler for like $120 second hand , how much you reckon it would be to put a new system on my car ?
just frustrated at the crappy sound my $2 tin can is making
i know that sound youre talking about Mitch, heard it on many other N/A skylines. ultimate poo.
a proper 2.5'' system with extractors, and resinator should have it sounding much better
yeah it actually pisses me off , tempted to get a stock system cause i hate it so much
yer i know but i have nfi wtf to get :)
aussie dyno and tune Port Rd hindmarsh, Say your off SAU. Cheapest in town.
fisher performance did my n/a 31.. and it sounds very good.. advanced headers, 2.5" exhaust, hi flow cat, turbo mufler, and a resonator for $1000..
def happy with that.... the best part is it doesnt drone at 60, 80, or100kph
Guest
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
