Stupid computers today!
One reception PC power supply has died.
The receptionist can't log on and get her desktop up on my share PC in my office ... so I've put her on my drafting PC.
So I'm stuck in my office using a less than adequate PC for drafting today!
IT guy should have been here an hour ago! I'd do it myself, but I'm too busy for that shit. :P
Hello all Forum members - finally we have joined SAU
Team wheelworx
Welcome aboard. :P
$200 a week I heard, just to drive that yank tank to work and back each day. Bloody hell :laugh:
Good point! The Evo's used to be alot more 'boxier' but have now made them a bit more smoother. They both have similar front ends, too - complete with the bonnet vents (but Evo's have had this since the day dot).
Nissan just can't get away from those headlights! R35, 350z and now the 370z will have them, too!
any one else think these cars share very similar lines??
Anyone else think they both look like shit too?
Can't stand new car design. Whether it's putting massive fk off grill areas (like the 2 above, and Audi is a culprit of this too) or headlights that creep half-way up the bonnet or complicated panel work (looking at you, BMW) theres just something that shits me about new cars.
Tasteful and restrained, 2 words that seem to have disappeared out of car designers vocabulary over recent years :P
gezzz mick ur getting ur post count up quick lol
should i stop posting stuff now or wait till later........hahahahaha......not much else to do and some of these threads are pretty good for a laugh......
besides being social beats the ps3...lol :P
Guest
    • Should add all mods on the car are done in my ownership. The car was a 1 owner in Japan and I'm first owner in Aus.
    • Thanks GTSBoy. Did BC's so not Japanese coilovers. I've already done all the other points you mentioned besides the seat, I like the factory seats and want to keep original look. Done all the fluids and comp tests etc and all consistent and clean. Well and truly used to the power and car as I've been driving it for a few years as it is now. Contemplating next steps mainly. Preference to remain twins too. @Murray_Calavera Paying for labour.
    • Hmm. I don't think it is possible. As soon as you start, you will be on the hook for all the money. $5-10k is enough to make it fragile. Here's the list of things you need to do to make it nice, and driveable. If Japanese coilovers, get them measured and tested, then decide if you're keeping them or replacing them. If low rate springs, then consider big ARBs. If high rate springs, then probably leave stock ARBs. Either way, ad decent end links. Replace and/or upgrade all suspension bushes. That's LCAs front and rear, UCAs & traction arms at rear, caster rods at front. I highly recommend GKTech FUCAs, although the step to spherical joints is a step too far for some people. Rebuild brakes front and rear. This means making sure the calipers are healthy, discs are up to thickness, hoses are replaced with braided. Add good pads and fluid. Investigate wheel bearings all the way around, tie rod ends all the way around, upright bearings at the front, balljoints everywhere. Any of these that are still original are likely to be a bit wibbly nowadays. Bride or Recaro driver's seat, with fairly deep sides. Nice tyres. Street performance wheel alignment. Or track focused, if you're not going to use it on the road. Fluids everywhere if not known to be fresh. Now, learn to drive the car as hard as it will go, before trying to add any power. Save up big $$. $5k is the minimum cost for putting a decent ECU into it. A big single, with manifold, new exhaust, injectors, fuel system upgrade, ignition upgrade, triggering upgrade, etc, is >>$10k. None of that (except the ECU) is a good idea on an old RB. You really should put head studs in it, investigate engine health (compression and leak down, real oil pressure at revs, coolant condition, etc) before even considering adding power. There's nothing sadder than the "I added boost then it shat the bed" thread.
    • Are you doing the work yourself or are you paying for labour?
