Hi everyone im back :P im now living in my new house :huh: my laptop shat itself last week so i gave it to my mate to fix and only just got it back today, so what have i missed??
everything babe just go back about 300 pages and you will be ok
Rb30 keeps the 4wd and the low mounts (as low mounts are part of the head).
Everything bolts on as per normal. The sump adaptor bolts on to the bottom of the rb30 block and then on to the 4wd sump/diff.
3k.. Sounds like an AFM issue. Make sure all the IC pipes are connected properly.
probably roughly 10k i assume for HKS version
Wanna keep the 4wd tho, and twin low mount's
Also Cubes brother has a R32gts-t got new coilpacks, plugs and serviced recently. anything over 3k the car starts chugging, any idea what it would be?
what cubes said! tell craig to get another afm. if he wants he can test mine out on his 32.
the cars gone into limp mode or whatever its called. happened to me and its a pain to drive!
hey ruby.... looking at getting a motor bike...
wats a good bike to look at? beginner also :thumbsup:
why you asking him.........you know what he's gonna say
"if it aint Italian, it aint worth havin", lol
Here's a bit of education for you:
2008 Fat Boy
2008 Night Rod Special
2008 Road King Classic
oka so should i go a hks hipower or a hks silent hipower cat back exhaust for my 32???
oh and will an R32 GTR cat back one fit a gtst/gts4 ??
need ya opinions
cheers
Edited by vinnie32GTS4
well, Ive been quoted petrol money change out of 2grand to fit and tune the following:
Cometic intake manifold gasket
Cometic intake collector gasket
Cometic exhaust gasket
Cometic Head gasket 1.2mm x 87mm
ARP head stud kit
EPP 6mm viton Intake valve seals
EPP 6mm viton Exhaust valve seals
EPP Intake valve seats
EPP Exhaust valve seats
EPP Intake valve guides
EPP Exhaust valve guides
Q45 90mm throttle body
Greddy Q45-RB25 adapter kit
EPP clear cam gear timing belt cover
Tomei oil gallery restrictor orifice
Tomei hi-lift valve springs ~8.8mm
Tomei 256/256 poncam camshaft set
Gates Racing timing belt kit incl. tensioner and idler
2x 700cc Sard injector external intake manifold setup
ryco oil filter, oil filter magnet set & Motul 4100 turbolite 10/40w oil
Need a controller for the extra injectors tho........................
expect, with the sards, there should be enough fuel injc. headroom to push a nice comfortable 230kw tune., with heaps big torque
:thumbsup:
then thats it, bar pistons/rings and rods/bearings; maybe in 5yrs time. lol
Guest
    • You're 20 years too late mate. Used to be 80% skylines back in team trackday days
    • There's a lot of drug money on that side of Sydney. Just sayin'.
    • At SMSP, I mainly see Hondas, M cars, A90 Supras and of course, plenty of Evos. Have not seen a single R32 ro R34 Skyline on the night sessions that I've been to. That's really saying something.
    • I like mine. Much better than stock. Like i said before the reverse/parking cameras look even worse than normal, still useable. When you buy one make sure it's the latest version. Heaps of cheap ones that run the old hardware and software. Got mine from AliExpress. Mine is quick no lag, boots up 1-2 sec. Menu is fast. Netflix is fine and so is YouTube. Android Auto is random taking 3sec to 15sec. Most of the time it's quick. Very rare it doesn't connect. But that could be a phone thing.   Now I think they use a Pixel 3XL to run this whole thing which i guess is fine, but the problem is that some apps will not work on old hardware like Disney Plus  Maybe Prime Video too 🤔. they will not update. Iv'e tried getting the APK Disney + but i still couldn't get it working. I have a Data sim installed so i have internet all the time. You can't Hotspot off your phone and connect Android Auto at the same time. Not that you need too, if you want you can hotspot off your phone and run any internet map app (google maps) and you can run the Spotify app on it's own (the app runs better than android auto) You can still access the INFINITI intouch system for all the o.g stuff    P.S i got new non Polarization Sunglasses too 😎
    • I also don't mean to rain on your parade. But with a 5-10k budget for road only? I'd want to check confirmation that everything IS working correctly and I'm with @GTSBoy for a plan of action here. I'd be checking subframes, bushes, exhaust hangers, interior bits and generally QOL things and CONFIRMING they are working right before thinking about motor. You can get 250KW+ on stock RB26 hardware by simply removing the built in restrictors and tuning the stock ECU. If you want purity that's as far to take it, which I would be worried to do and won't think the budget would allow for when earnestly checking for 30+ year old car stuff.
