:D yeah good luck with that.
Go the 31 if you just wanna go out and thrash something. Take your 34 out there if you want to learn more about the car/driving in general. Once you get over the fear of bending a good car its much more fun.
AE86's START at 9k imported...
And that's with only 10% covered in rust!
dont know where you 2 guys are looking for AE86's
http://www.tradecarview.com/used_car/japan...trueno/1455433/
http://www.tradecarview.com/used_car/japan...trueno/1381123/
http://www.japaneseusedcars.com/auction/tu...o-28691719.html
http://www.tradecarview.com/used_car/japan...trueno/1111544/
http://www.tradecarview.com/used_car/japan...+levin/1515519/
and there not the cheapest spec ones
Hmmmm
need money :P
50mm wide body rears for a 32 4dr ;)
Would look fking ace with some GTR front guards & bar.
find those for a R33 4 door and i will love you for ever
I got fruchocs and coke! Close enough.
So im confused but agree with Adrian KEEP IT OFF THE DAMN FORUMS!
i used to work a robern menz :down: mmmm chocolate coated orange bits
Boring.....
Bitching on the net is gay and having to read through it to find the good things to read is even more homo. Is SAU full of 16 year olds now or what?
Because I'm bord, I'm going to borr you all with me. Here's some dodgy pictures I took not long ago. It's only a shitty old camera and ive never done anything fancy with one before so cut me some slack :D
all depends on the yen on the day general rule of thumb
car cost Yen FOB = at the docks
$1100 shipping+10%gst+10%customs+$600 Quarantine & other government charges+ $3000 compliance + broker fees
OH YOUR SO BORING KYE...
.no really you are JK lol good job man
PLEASE!!! i would kick your ass at halo and i dont even touch that gay-box 360 anymore :D
dont be mad dan, one day ill let you back around to play some more ps3 :down: .................................one day
cheers steve ;) you funny bugger
Edited by Import S13
Those pics r sex. Love the paint job.... wish I had one as good ;P
-D
thats gaylo 3 to you
and way to make me realise the tool i am having to nag the rich kid to play the latest and greatest games :D can i come over mum says its ok
im still playing galaga here, apparently games have moved into a get this "3rd dimension"
forgot to put ur window up ;) n get a night kids sticker
Edited by Inline 6
Guest
    • There's a fair chance that my bushes are Nismo, because I'm reasonably sure that when asked the question (when putting the subframe into the car in ~2012) "What bushes do you want to run?", I'm pretty sure I would have answered "The stiff ones!". I had to put some silicone grease onto the GKTech inserts I jammed into them last week, because the bushes were quite resistant to having something jammed up their jacksies. So, I reckon you'll be best off doing Nismo + inserts. And, if I'd known you had PU bushes in the subframe AND PU pineapples, I perhaps would have said earlier that that's probably not a good idea. The pineapples are only intended to work with the stock type bushes, because those have a crush tube (which is what makes it end up looking like there is sloppy space in there - but doesn't, because the crush tube does make contact steel to steel) and the pineapples live in the space between the subframe's outer tube and the lower washer/bracket. But the PU bushes don't leave the space in the same way that the stock format ones do, and they do end up fighting for space. Order some bushes and collars and get to it.
    • Thats the current state of the reo. Bit ew, but GTR Reo and supporting bars are $2000, and 2nd hand GTT ones are $1000... More engine disassembly. The good news is   Various LS weird sounds are apparently normal Everything coming out is in perfect condition The bad news is: Everything coming out is in perfect condition It looks like whoever assembled this engine ~25,000km ago was telling the truth with what's in it and how they did it. Even things I was unsure of like the timing chain - But it's a brand new double row timing chain, spaced perfectly. They even cut up the stock windage tray to keep it instead of being lazy and to work with the baffle. Cam, Heads, springs, LS7 lifters, Pushrods - All look new and have obviously been working perfectly. In other news, we removed the pineapples that were loaded below the superpro subframe bushes. They look a fair bit munted and have deformed the poly bushes that are 'above' them. I'm telling myself that now that there's space 'under' the bush between the little cup that bolts in... that having a pineapple wedged there was bad and basically made the rear end solid. The pineapple and the superpro bush are ... equally deformed (i.e they have deformed one another from being smashed together). We'll see how it goes with bushes only. I am sure this cope will fail and the answer will be to drop the subframe and put nismo rubber bushes in there instead. $400 worth of gaskets and ARP head bolts to replace perfectly new looking gaskets that absolutely weren't leaking  and were installed perfectly with great care - because god damnit.
    • Why bother? Keep them under 1bar and be happy, I had it for 10 years and never had an issue. once you go beyond that the budget blows out fast and then keeps on blowing out
    • I'd still recommend rebuilding the turbos too. That will eat up a lot of the budget especially if you aren't willing to put in the labor to R&R the turbos yourself but it's a huge risk to ignore it at this point.
    • Can't help it, its an illness.
