WOW sounds good Allan um i imagine once you go ppg that will be full manual and then no need for traction control yeah
true just have to see how she is on the road it would be good for winter time its ment to be able to figure out how much power should goto the ground so you dont skid around i think it might be worth getting
little info onit
~Click Me racelogic traction control and launch control~
Whats a good turbo choice for the RB25? Getting tired of the Slide stage 2 turbo lag. Want to consider something with a bit more bottom end punch but can still handle 14psi safely.
Looking to get Shaun to tune the stag soon, but would like a better suited turbo if I'm going the expense.
:rofl:
http://www.skylinesaustralia.com/forums/Rb...yno-t55845.html
Thats probably a good place to start Rubes.
Read that before, but not much on-street feedback, but alot of power figures. I want useable power. The 2871 sounds right, but wondering if there are more. :rofl:
in order of decreasing responsiveness and increasing power.
GT2871R (56T)>260-270kw, GT3071R>280-290kw, GT3076>320-330kw, and then you go into GT35 teritory which i don;t think is what you are looking for. you then have the choice of what rear housing to use, 0.6* for response and 0.8* for power. Personally i would go for the 0.8* option so you don't choke the power in the top end, but you said your after more punch so you mightn't agree.
EDIT!!
The power figures quoted are rought figures and you will be running more than 14psi to achieve them.
Edited by D_Stirls
entertain me hehe
Welllllllllllllllllllllllllll :P
j/k
Sorry to hear you're sick babe. Tracy aint the best either at the mo. She's off work today, so I'm off home in 45 mins to see how she's doing.
Guest
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
    • Oh yeah, always always always turn over an engine by hand first.
    • So by that logic, an insanely expensive GTR for $200k+ is quite cheap, at 12% of Sydney's median house price compared to over 50% when a GTR was new...
    • Apologies... thought i had outlined it... Cheers for the response, I'll get a nipple sorted out for this.
    • lol thanks for the pics but some arrows might have helped for context. If you mean the bit I've badly traced in red, that is a PITA vacuum signal for the power steering pump, only R34 GTT was "lucky" enough to get it. Yes you will need a nipple of the same size somewhere in the intake between the air filter and the throttle or the power steering idle up will not work correctly
