slide stage 2 is a 360degree journal bearing rb25det turbo, oil and water cooled, with max hiflow port work done to the front/rear housing, and big steel wheels
with timing and fuel deliverie issues sorted at various rpm points it should be anything but laggy; very very close to stock in terms of minimal lag
I'll get the stag to Boostworx then with the current turbo and see if Shaun can smooth out that lag then :P
good choice ruby!
sorry to hear craig, 98 is a good knock tho
andrew, was willing and ready for a blast down to victa, n/m
warm weather hey, weird side effect from the fentynal patches is massive random sweats
sux
that's the one that was sitting at wilall a month or so ago! and isn't the osgiken 3litre insane? i know of a dude who has keir's old engine in his track prep r32 with 2 trust t51's i think, it pulled about 420kw? with over 1000nm of torque and i remember when he took me for a spin! started off in 2nd and ripped up the semi slicks like they're nothing and man can this guy can drive as well
Yeah mate that's the car - and Munro's engine is the identical specs to Keirs old one, and is making about the same power too. Very scary, but a lot of fun.
Sorry Brendan - I didn't see your post until I got home. But you wouldn't have been able to keep up, in all seriousness .... we were going *cough* a bit fast - to give you an idea we did the 50km from Delamere to Victor Harbor down Range Road (favourite road in Australia) in under 15 minutes .... maybe next time :P
cant believe the OS Giken block is worth $30k!
yeah me neither - and Munro has 2 of them - one in his 3lt streeter, and one in his race GTR (which is nearly finished and will be running over 500rwkw again on E85).
Betcha $50 I would have kept up :down:
in all seriousness too - Im not a betting man, but One Id take 'cause I know Id get a free fiddy (no speed limiter, good suspn.)
:D
alls good, I knew I posted too late, should have posted at 7am doh
and yes I know the delemere rd very well, favourite road as well for me, closely followed by clarendon thru meadows to the end; strath-goolwa turnoff (damn got a brain fade on rd name)
one of my friends just picked up a vr4 4g63 motor, gearbox and a full aftermarket turbo set up with ex-gate, manifold etc for stuff all
he only wants the gear box for his car.
doesnt anyone know of any rwd cars that we can get CHEAP and dump the motor into or does it have to be fwd or awd to work?
I've heard crazy rumours that the engine is a bolt in proposition for older model RWD Lancers (like gearbox and mounts all line up).
I have an older model RWD Lancer, I think we should test this theory :D
Nah I read somewhere the factory rally team (or a private one, can't remember) using the old lancer chassis put one of the first 4G63s in, although in typical internet fashion this is probably a crock of shit.
Still, my Lancer is an A73 I think, the first one, with a 4G33 engine. The engine code is similar enough so you never know.
yeh thats what we were saying! On main roads too!
Was talkin to the lady at the local corner shop, said that one of em got hit by a car runnin away or something, but has been caught.
Watch channel 7 tonite i guess and find out the details.
I can't believe it either.........I doubt if the block alone is worth $30K........maybe with very expensive internals ie. a short motor
Guest
    • Connected to plenum towards the rear end. Yes, absolutely required for the ECU. Even Nistune can't save you if you don't have it.
    • Can confirm solenoid makes no difference. I finally removed the solenoid and the wire off my engine loom and there is no issue with boost. Keep in mind, this is the solenoid, and I've got a Nistune. After the boost controller, I ran the car for a day with the solenoid unplugged - no issue. So then I just ripped the whole thing out. Like @GTSBoy mentioned before, the ECU just sends an earth signal for the 2-stage boost. And looking at the wire going into the solenoid, that just had 2 standard wires and did not look important 🤣 As for boost sensor: I saw somewhere that the vacuum line the gauge uses is at the back of the engine on the driver side. I never touched that but assume ECU uses that??? (maybe? Just assuming)
    • I still remember it trying to rip the steering wheel out of my hand when I put it into a 4wd power slide lol
    • Im also amazed how well Attessa holds up to all of the abuse. Especially with the burnouts and crap you guys used to do at Texi!
    • True! I think I'm closer to 06 with the cameras in phones being out there more. And the nearly impossible to use internet web browsers. Or paying for ring tones... Man I hated when we couldn't just compose a ringtone on a Nokia anymore! These days I just hate it if my phone rings, beeps, boops, or vibrates!
