i vote do it, if you got the nasty holes on the boot from the missing wing could be a good way to cover them while making it supafly
looks like the vspec wing after a closer look no it aint no vspec wing but a simmilar nice style
Edited by Inline 6
dont you mean.......Never oily, Never dry......?!
adrian, nothing wrong with plasmas ive been told, its all about what YOU need it for...
movies and sports =plasma :banana:
Edited by craig R33
i say go the cinema screen,my setup is awesome,i play games watch dvds and due to my tuner watch full hd through projector onto my screen and cause of my surround sound its always cool to watch anything
Well finally got the internet set up at home again :banana: Upgraded a few things with the PC too.
Now I'm setting up the security PC. I'll be able to log on and view the video surveillance cameras I have at home from work or any web connection. :P
Think I've taken home security a little too far? :)
lol adrian, i didnt want to soend 2600 + on a sony bravia, which would have been the only lcd i would have bought
picture quality is amazing!!!
but i cant complain, 1200 bucks for a 42'' plasma = :banana:
hehe... lol its harder for me as im with them all the time and i can pick the difference.. lol plus im fussy but yes GOOd buy!
like i said my grannies is going strong and shes happy lol
Lol Dan, you're a funny boy
Hey Pete, talked to my mate today about your shed, he can do it but he's booked out till Jan.
Thanks Chad, I was thinking to do it in the New Year anyway so I'd be keen to hook up with him at some stage.
While I got you here, I spoke to Andrew (Blue 32) through PM's about going around to his place one day and checking out what he has now done to his car while sucking down a couple of beers and talking rubbish. I told him I might drag you along since you've got a 32 & done a track day with him but I think he's coming to the Dyno Day at Boostworks this Sat so we'll catch up then.
By the way, IMHO, no additions to your bodywork, but that's just me.
Guest
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
