Oh cool so I can lose the massive text then? :down:
*edit* yep after looking at it just now when my post showed up, doesn't really need to be that big aye :D
*goes off to my controls...
Edited by AndrewJZX100
well i just got pulled over by cops..... saw them come up so i stopped and got out and had my licence ready, he said this your car mate and i was like yeh it is sir. then he said just take it out of the garage and i was like yeh bit dirty hey. he was like rego'd under your name. i was like yep. then he was like have a good night.. wow i was shitting myself.................
The speedo cable is way to long.. I unclipped the speedo cable up front and have it looping down slightly.
Hard to explain, get under the car have a look where the speedo cable comes out from the firewall and see the brackets that its attached to. Remove the attachment so it loops more so then it will be the correct length.
ah yeh i understand!! thanks...
gearbox is making noises all of a sudden :down: god damn it! its like i can hear bearings turning... the more revs the louder....
sometimes i wish i still had the 20!
went the vertex front bar??
how about sides and rear?
yeh got it dirt cheap off a mate.
Just got the vertex front bar atm with the type m skirts and rear bar but i have got a vertex rear bar sitting at home...still deciding wether to put it on or not??
Edited by vinnie32GTS4
HA! see even the coppers love no kit + fitment :down:
Good to hear nothing came of it.
got my 32 back today...absaloutley loving it :down:
only a couple things need to be done like wheel alignment n what not but yay
heres a pic i took with me phone
Hey man, looks good, but whats with the non matching head lights???
gearbox is making noises all of a sudden :) god damn it! its like i can hear bearings turning... the more revs the louder....
suck it up, you've just done a whole comversion so be patient with it. Not everything goes perfect first time. Your few little issues have been very minor. I bet it's the thrust bearing that i told you to replace hehe.
It'll all work out in the end.
Good to hear about the cops!!
Edited by Ryanrb25
suck it up Princess, you've just done a whole comversion so be patient with it. Not everything goes perfect first time. Your few little issues have been very minor. I bet it's the thrust bearing that i told you to replace hehe.
fixed, much <3 :)
Did you replace the spigot or more importantly make sure the motor had a spigot?
Mate of mine did similar.. Assumed there was a spigot. Ended up stuffing the input shaft bearing. :S
he he sorry! yeh im very happy with everything!! yes i know the thrust bearing :)
haha i dont know?? ryan??? lol
haha cubes its funny you say that, ive run into that problem a couple of times in the past etc and now i check religiously...yea the motor had a spigot and it was healthy. It it most likely the thrust bearing that i recommended to change but never got done. These things happen.
yeh i should have listened! sorry ryan... :)
thats something i can deal with ne ways!!! and its puerly my fault.. at least everything ryan has done has been 100%
adrian= fail hahahahhaa
ryan = WIN
Guest
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
