Plug in 66% as you had previously or slightly less. Might be worth going a little leaner with 60%.
When cranking go full throttle.
It probably won't start because the plugs are wet fouled then its just a big vicious circle. :S
i tried that the other day to no avail.
Adrian, we need to pull the plugs out,start again..I'll get it going after the job interview.
Edited by Ryanrb25
well.........
the car seems to be running on 4cyl with the new injectors in.. so out the injectors come and off for a flow test... hope two arent f**ked...
oh well we will wait and c how it goes... its all a learning curve!
Checked the injectors are receiving power with a multimeter?
The injectors always receive volts so simply turn the ignition to the on position and check with a multimeter.
The ecu earths the injectors to trigger them so obviously shove the neg of the multimeter on the chassis/battery.
Runs on 4.. Are you sure the plugs just arn't fouled.. Thats what a mate of mines did for a while we warmed it up, raised rev's and she cleared up. :huh:
Not in the mood.. Go and have a bat. lol.
Run it for a good 5mins or so with rev's slightly up.
Make sure the injector correct is set right so go with 'slightly' lean at 65%
.... It could be running for the weekend ...
Another way to check the injectors are firing and when they 'should' be firing is to pull the cas out; ignition to the on position and then spin the cas clockwise slowly when looking at the shaft from behind. You'll hear the injectors click click click. Make sure they follow the firing order. :unsure:
[Vent]
Put turbos back on, sell car?
Pay for removal/reinstallation and just take it in the nuts?
Sell engine, buy R34N1 engine + turbos and apply for an engine conversion?
In SA, that actually seems like a good idea....ARGHHH.
[/vent]
yeh ive done that before but not with the new injectors.. ill give that a crack later..
if there not firing wats the go? there rooted?
[Vent]
[/vent]
how much for the n1's? my car needs a chrissy present
If there not firing its multimeter time to see if the problem is with the loom or the injector.
Guest
    • Strictly street. Just wanting a bit more power 🫡 Have baby seat in the back too 🤣
    • Yeah ok, it'll be expensive. But it is what it is.  How do you plan to use the car? Any track work?
    • I do have their “Nissanie Motorsports Co.” vin plates, but I am curious if anyone would have more info on them. Like how many cars they’ve imported and whatnot
    • Been a long while since i have updated this money pit lol.  Have had a few tune related issues with the car, first blowing the frost plug out the back of the head and then blowing the headgasket 3 months later, which has now been retuned and sorted. Done a few little changes along the way as well, i wasn't happy with the wheel and brake setup, so start of last year i managed to get myself a set of r35 brakes and nismo lmgt4 18x10.5 +15 Upgraded to now running a Precision Gen 2 6870 with a 1.15ar, to be honest felt more like a downgrade as the car feels much lazier around town compared to the Gen2 6466 previously. 0761719E-5683-43F7-BD3B-4BD94335DFF4.mov
    • Hi there, i am currently using the Elmers Racing Billet merge collector, we are using sch40 tubing and 1.5" ID, no cracks so far. however if i was to do it again, i would go sch10 with 1.25" runners
