would anyone happen to know where i could go get a nice sounding exhaust for my lil 125cc bike? ^_^
East 50s on Payneham Road. Tell Brian that Reuben sent ya.
Or try see what the boys at Pooraka track has on their wall.
Edit: This is the extract from the info bulletin 3.
Roll Cages
Due to the increased risk of occupant injury in vehicle accidents the fitting of full roll cages are not permitted.
However, the fitting of a roll cage rearward of the driver is permissible providing that:
a. No part of the roll cage is contactable by vehicle occupants when positioned in their normal seating
position.
b. The roll cage is at least 150 millimetres rearward of the front seat occupants when the front seats are
located in the most rearward adjusted position.
c. All rear seats and seat belt assemblies fitted in the rear compartment are removed.
d. The operation and effectiveness of the front seat belt assemblies is not affected in any way by the roll
cage.
e. That no person travels in the rear of the vehicle at any time.
Also, the car has to be re-registered as a 2 seater.
Edited by Eddyfier
Wooo
Put some new plugs in my car and theres a noticable improvement in smoothness now :woot::)
Still needs the oils and clutch to be done this friday, but cheering I could work on it for a few hours (I put the stock intake back on also) and come out of it with something positive, not really often that happens :)
Once the clutch is replaced, all it'll need is a touch up tune and then hopefully I can ease up spending money on it and just concentrate on driving it.
while I was out there I also measured my ride height after looking through the regency thread, it's at 345mm front and 355mm rear. In other words, it's legal height, and therefore CANNOT be defected for too low :)
Edited by AndrewJZX100
QUOTE Roll Cages
position.
cage.
this the only part i would be concerned about, what part of your body do they measure from??? im not sure the cage would be far enough back.
I'm not 100% sure but I think they put your drivers seat to the rear most position on the rail (I'm not sure if the recline the seat as well) and measure from the very front of the cage to the very back of the drivers seat.
Guest
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
