Holy shit bags! :banana:
yeah gotta love it, the media see a skyline tag and instantly its a high performance vehicle
let alone the fact its an r31 4 door...
rear does look jap, esp the 2" single tail... looks like an import
camera angle is from the angle the car entered, the front snapped off and is bent around the section that isnt visible
typical sensationalist journalism. pathetic.
oh and good luck to the kids in there, that was a hell of a hit regardless of the shoddy reporting. i think if they survive they'll be taking the bus for quite a while.
-D
well that sucks, it didnt quote what i wanted
basically in addition, the bit about the seatbelts / seats having to be removed, they forget to mention that you cant just put the bolts back in the seat belt mounting holes. they have to be welded up so that you cant use them again. seems stupid IMO
There are ways around this that aren't so permanent. If you want to know PM me, I don't what to post up in there because I don't want the SPYs to know :banana:
well thats feked!! since when hast been so FORMAL??
we're just trying to keep the riff raff out. :banana:
edit: the 31 in that story does appear to be an import, bootlid, rear door and lack of b pillar (not just cut off, there wasnt one there, period) seem to give it away.
Edited by scandyflick
lol, up early dave
agreed, is HR31, also the badging gives it away (as ive not seen anyone go to the attempt of badging an aus 4 door as a Passage GT lol
any auto elec gurus want to give me a hand. for some wierd and wacky reason, my brake lights have stopped workin on my trailer. every other function on the 7 pin plug works (parkers, clearance lights, indicators, electric brakes) just not brake lights. couldnt find my test light, so was testing with a multimeter and couldnt get a reading at the plug on the back of the car
anyone want to come and suss it out for me? either that or if ya in the area im going to be ripping whats left outta the 31 so feel free to drop by
well im still stuck in Bangkok, was suppose to leave this morning at 8am for melbourne but the f**ken airport is still closed due to bloody protestors taking it over so i cant leave until thurs morning if its open and if its not we gotta travel 4 hours to a military base at 4am to catch a flight home so i gotter take 4 days unpaid work let alone pay for extra accomaodation, this holiday is turning into a nightmare, i just wanna come home plus i cant ring anyone coz my phone was stolen so i have no one's numbers
HELP!!!!!!!!!!!!!!!
HELP!!!!!!!!!!!!!!!
far out...if that happened in Aust, they would put you up in a nice hotel with at least 1 meal a day at the airlines expense.....happened to 3 of us in Sydney a few years ago and ended up in the Hilton overnight with all we could eat in their alacarte dining that night.
Guest
    • Hi Brent, I am wondering if you ever worked this out? I have upgraded this unit to a newer one and everything works bar the reverse camera, so i really want to know what plugs are what so I can patch the camera through. many thanks in advance Mike
    • Once you have to get up in the morning and be useful, you suddenly value sleep it turns out :p
    • Update:   smoke test all pipes no issues cleaned reservoir   fluid put in ( dexron 3 atf)   steering turn side to side and could hearing  gurgling from steering rack which I assumed was air lock, opened one of the steering rack connections and could see loads of air getting pushed out( not sure if you meant to do that / whether it will re introduce air into system)   anyways, loads of side to side sound was gone. Turned car on, pump was slightly ( barely) wining so turned side to side few more turns and fluid level when car on was almost none in resorvoir which I guess is normal if car is one. Turned car of and fluid was gushing out. Almost 200-300cc was pushed out. Repeated engine off side to side followed  by engine on and same result       going mad now. It seems system is either sucking air in whilst on or there is tons of air which I am not giving it enough time to bleed. Thoughts?   would it work like brake caliper if I open steering rack copper pipes and let gravity pull all air out?   or maybe have a restriction somewhere? What is the red circled item, could that be blocked? It i
    • Yeah, the plan is to just put some black rubber vacuum line caps over them to "hide" them a bit I don't want to trim them in cause I need to put the OEM box back on at some stage
    • It's a load sense idle up valve.
