^chill out mitch, They are your neighbours...go in your room and play with your lego or something.
ryan your correct, its has a t3/t4 fange. not sure what 1.06 is can you fill me in on it.
cheers... michael
1.06 is the size of the rear housing on that specific turbo. A 1.06 rear on an rb25 will see boost far too late in the rev range. Your best option is to swap it for a .82 with an internal gate or .63 with an external gate to spool the turbo a bit earlier making use of the turbo on an upopened motor. By all means try it and it will still go fairly well, but you will pull it off later when you realise it's too laggy. A swap over rear housing from MTQ will set you back about 500-600 bucks.. Save yourself the pain and do it before you put it on.
Edited by Ryanrb25
just saw australia in gold class....
AWSOME movie!!! woot
I dont care what anyone says. You name a movie after a country and expect it to have any long lasting social value?
f**k no.
Luhrmann is an artiste. He's really good at creating unique pieces but cmon, last few movies he's made havent exactly been classified as realist.
I haven't seen this. I will though. And I hope my bias against this movie doesnt make me hate it unnecessarily. But whenever you try to summarize a country up in a 2 hour hollywood format movie, made for those people with short attention spans (and even less education about the world), then its pointless. So too is trying to find our national identity in a period drama. No offence to Campion, Weir, et al, but modern australia doesn't need to be reminded of colonial past; indeed its something that the nation needs to move away from, to truly embrace the potential of multiculturalism.
Anyhow f**kit. I've lost half of you already. Go drink more beer ffs, I know I will.
end rant.
-D
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
