all four? brand? type?
then maybe we can sus whether its a good deal or not hehe.
Find out if the price is fitting them aswell.
Ok, they're Dixcel Slotted Brake Discs, $350 a pair and Ryan's getting 2 pairs. Price does not include fitting.
What ya think?
haha carl, that barely gets me started. 3 cans of mother, 4 coffees, at least 1 iced coffee, and occasionally a redbull/v or 2 is my usual routine.
dixcel aint bad, was gonna get em for the 200, but tanked dollar sucks.
got my copy of 'cosmic motors' delivered to me today, freakin awesome book, i suggest everyone buys it, daniel simon has some freakin cool ideas.
FK SAKE
MY MUM IS OFFICIALLY FKD IN THE HEAD
she just invited the neighbours over AT 11:45PM ON A MONDAY NIGHT
so basically there are 2 fking randoms in my house now , WTF !!!!!!!!!!!!!!!!!!!!!!!!!!!!
Sounds like a usual Burnside night to me!
>_<
that's pretty cool
EWWWW MOTHER?!?!?! dat taste disgusting yuk xP
yeah, but it gives you da mad skillz to out run the jacks when they catch you doin 11tybillion km/h down pt wakefield road.
(interesting note, 11tybillion isnt a spelling mistake, wakefield apparently is.)
go boostwerks you good thing !!
new mechanic there too this week onwards, now 4 of em. Shaun & Troy, Adam the apprentice, and Andrew the new qualified mech on site.
so hopefully they can do better turn around times on upcoming work, thats Shauns aim anyhow.
not in a hurry for mine back, just want the best job possible on the head rework and a top (safe) tune, for least $
>_<
im stuck at home dosed on meds, back from my second visit to hospital in 2 days, unable to go for a drive cause im too dizzy from the meds, and still havent a damn clue whats wrong with me. its awesome.
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
