Hello all!! i have a day off... i'm cooking and watching the dogs act like tards... how is everyone today hmm??
YAY for day off!!!.. im just at work, but its like a day off becuase i have no computers!!! =D
hows things nene??
im stuck at home dosed on meds, back from my second visit to hospital in 2 days, unable to go for a drive cause im too dizzy from the meds, and still havent a damn clue whats wrong with me. its awesome.
yeah, it kinda sucks, i have to go to hospital every day =\ too many sick people!
are you shedding limbs yet Dave?
not yet. but i have to go back in this afternoon to make sure my brain hasnt decided to evacuate from my skull...
... or so im guessing.
go boostwerks you good thing !!
new mechanic there too this week onwards, now 4 of em. Shaun & Troy, Adam the apprentice, and Andrew the new qualified mech on site.
so hopefully they can do better turn around times on upcoming work, thats Shauns aim anyhow.
not in a hurry for mine back, just want the best job possible on the head rework and a top (safe) tune, for least $
>_<
Wow, they hired another mechanic?! Hopefully this one holds up their high quality of work, as I'm getting a brake overhaul done in 2 or 3 weeks at the 'Worx!
Should improve turn around times as you said, too.
hows things nene??
can i bring my dog to come around and play with your dogs ? btw what are ya cooking not bloody cupcakes i hope
Yeah things are good :laugh: Gonna try and make it to Villis Friday !!
What kind of dog do you have? mine are staffies and they are rough as guts! Not making cupcakes, making pasta bake, potato salad and marinating meat for the bbq!! Roo is coming round for dinner... Lets hope he doesn't wake up dead!! :rofl:
im dead from under-eating.
dieting ftl. I NEVER FEEL FULL FROM EATING HEALTHY SHIT!!!! WHY CANT PEOPLE GET IT THROUGH THERE HEADS!?!?
:rofl: i would kill for a greasy marinated lamb chop right now!
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
