mmmm, lf-a. do want. hardcore barely disguised race v-12 engine, mid to high 400kw @ near enough to 10k rpm, where do i send my kidney again?
shits all over the 35 huh.
well.... yes.
from the little I can see, I likey.............need to know more about it and can I afford one when its finally released over there?!
probably be close to $300,000 when it hits. if theyre still going ahead with it. new supra's been canned, lf-a is on thin ice.
cant be arsed reading the article that was posted after this, is the toyota/subaru rwd fun car?
Took the bike to Neville Lush Racing at Victor Harbour today for a run on the dyno......finally!
Wil try & post up some video later......even with ear muffs, it was very loud!! :)
i'll guess 100 rwhp.
also you spelt "harbor" wrong.
Fixing the airlines.
Dump the
male flight attendants. No one wanted them in
the first place.
Replace all the
female flight attendants with good-looking
strippers! What the hell, they don't even serve
food anymore, so what's the
loss?
The strippers would at least
triple the alcohol sales and get a 'party
atmosphere' going in the cabin. And, of course,
every businessman in this country would start
flying again, hoping to see naked
women.
Because of the tips, female
flight attendants wouldn't need a salary, thus
saving even more money. I suspect tips would be
so good that we could charge the women for
working the plane and have them kick back 20% of
the tips, including lap dances and 'special
services.'
Muslims would be afraid
to get on the planes for fear of seeing naked
women. Hijackings would come to a screeching
halt, and the airline industry would see record
revenues.
This is definitely a
win-win situation if we handle it right -- a
golden opportunity to turn a liability into an
asset.
Why didn't Bush think of
this? Why do I still have to do everything
myself?
Sincerely,
Bill
Clinton
Guest
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
