finally i think the airport in Bangkok will finally open tommorrow so i can f**kEN come home if not i gotter travel a further 3 hours at 12 am to a military air base to catch a flight at 8am.............i just wanna come home and pick up my car and so Ryan can put my new bakes on........all ive been doin is shopping and wasting money coz im that bored
Could be worse man, at least your comin back....see ya soon!
might be a bit of an out there chance
anyone got a CAD file for the bottom half of an RB20/25 inlet plenum (the runners to the block)
mate of mine is going to be knocking up some custom forward facing plenums, and needs a cad file (or at worst a spare lower plenum half that no-one wants) so he can get started
who's ya mate work for matty? how is he making it?
he works for etsa lol, he's got a bloke who can cut the stuff out of 16mm aluminium
he did briefly explain it but i was driving home from work when he rang me
all good, he had started to mod a standard plenum (until i got highlighted the negative side of that), and he said it was hard to weld new material to existing. was going to be much easier to go all new instead
MAN i just replaced the negative battery terminal clamp... and god damn that was a fricking pain for something hardly significant at all. I cant be ass doing the positive - I'll do it when it becomes a problem. Damn the idiot that designed the battery in the boot directly under the parcel shelf.
ruby those vids remind me of a certain kmart tyre place
now i was in mums sic commo when i was waiting on a very busy to turn right, was there with crazy traffic for like 5min atleast.
finally gap about to happen and i look up at kmart at this fool that appears to be about to snake me and pull out before i can from the private rd. he rolls out sure enough and i notice he aint turning i think who the f is this idiot driving and look in the drivers seat no 1s there :rolleyes: the car rolls by scraps my mums commo on the side and i run after it trying to stop it from slamming into others cars. was having trouble stopping it from the window yank so stupid me stands infront and go's for the rugby scrum stop lukily i got it too stop and it didnt push me over but yeah tools tried to fix up the car half assed when i bailed them out of way more damage to other cars. dudes like fk forgot the hand brake
Edited by Inline 6
Guest
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
