Straight to the point, looked (by accident) the keys in the boot of the GTR... Boot release doesnt work, so.. How to get them out, havta catch the damn bus to work cos my daily drive keys are on there also :banana:... Raa be able to 'break in' to it?
Also was lucky the boot didnt catch on fire as the rear right hand light has burnt out the left globe and wiring, hence the reason i was in the boot, put my keys down for a second and with the frustration of the rear light almost catching alight i shut the boot with them in it... What to do? Any ideas.. Stupid problem i know.
cronic a little information you may have missed
hey wat causes missfire?
coilpacks, plugs...
i have changed plugs and gapped them, and used another set of OEM coilpacks and still missfiring.
any ideas on wat else i can change? coilpack loom??
coilpacks, plugs...
Timing could be way out? Did you plug everything in properly?
yeh timing was done when the water pump was changed 3km's ago lol...
im thinking the OEM coilpacks are not coping again...
s1 or s2
if its a s1 rb25det check the ignitor could be playing funny buggers just a suggestion.
Well the RAA dude this morning got the keys out, dont know how as i wasnt there, apparently they have a 'special way' of opening a boot lol
Anyways all good, thanks for the help people.
Now to buy a new boot lock, anyone know where i can buy one from? Thinking nisswreck or similar..
Whootage
Cleaned my car just before, the piece of shit actually tubs up alright (if you don't look at the back) :)
Also swapped the innards of the dizzy over on the poobucket daily and it drove roughly a million times better. Still got a very occaisional misfire, but it's been run down to 5/8ths of fk all petty a few times and the fuel filter has probably picked up some crap, so I've got a new one to put in when I cbf.
All in all a good days work ;)
Edited by AndrewJZX100
Guest
    • What are your plans for your blow off valves? Purely plumb back? How soft will the spring in them be? AFM can be tricky to get super smooth and nice, especially depending on the rest of the system, and then can be very easily upset if something slightly changes. IE, even if you run recirc blow off valves, you could still see issues getting it to behave at certain load points as turbos might start to spool, but you release the throttle but it's not enough pressure to crack the bov open to recirc, and you can end up with reversion which can cause double metering, and hence dumping of fuel into the system, and stalling the engine.   If you're going to run a map sensor for closed loop boost control from the ECU, what makes you want to keep the AFM?
    • It's not bad, it's just not flexible. And say if you have any leaks between the MAF and plenum, well then your load axis goes out the window. Here's a real world scenario, I blew off an intercooler hose last track day, as the clamp decided to Bluetooth itself somewhere. Still continued to do 2 laps and drive it to the pub for a couple of beers then home. Good luck doing that with a MAF setup
    • Is MAF load really that bad? I'm not trying to do big power, my only real desire is VCAM and flex fuel support so I'm not terrified of blowing my engine apart from CA's appalling 95 RON "premium" fuel. Stuff like playing with closed loop boost control and really dialing in my transient fueling and ignition are frankly just to prove to myself I remembered something from uni.
    • Thats what ive been doing. Ive got a million questions but i know theyve probably all been answered before at some stage. Todays research included nismo heritage seat covers, s3 projector headlight retrofits and how to remove/paint the rocker covers
