also note i couldnt find it before
but i didn't go against what you said just to be an asshat it is documented a RB25 turbo on a RB20 engine is quiet capable of 14-15psi this is why i believe on a RB25 engine it isnt running out of efficiency @ 13-14
source
Have a look at some efficiency tables. People dont realise that it's not all about boost in alot of cases. A stock turbo works sooo much harder to produce 13-14psi than a much larger turbo. A smaller turbo working harder than a larger one has 10 times more heat than a slightly larger turbo on the same psi. Heat is the main cause for it's loss in efficiency. Heat is the main contributor for power loss. Heat is another contributor for detonation. Heat Heat Heat. 10-12 PSI is the effiency range for that sized turbo combination. It's been proven over and over and over again. It pays to spend time on all sorts of cars using different sized turbo's and watching power DIVE when you add any more HEAT and BOOST into a turbo that isn't efficient for those settings.
Also, you can't compare an rb25 turbo's efficiency on an RB20 because an RB20 if your unaware is a 2L. Being a 2L it has less stroke, less flow, less heat so therefore the effiencienfy range for that specific turbo goes up a tad. Efficiency can also be determined with front and rear housing not matching at a certain flow level. At 10-12psi the rear housing of the rb25 turbo is just large enough to not create surges caused by lack of flow in relation to how much the front housing is squeezing into the motor. Where as at 12psi and above, the front housing is flowing a tad too much volume for that tiny little rear housing to handle....sure it will cope, but it gets f**kn hot. Hense where the heat comes into play, in turn heatsoaking the front housing a whole lot more..taking efficiency away from the turbo. Another reason efficiency can be effected is because the front wheel of the compressor is designed to flow a certain amount of air at a certain speed. Just like a water pump, Behaving fairly simular, if you speed the front wheel up and the pitch of the front wheel is incorrect for speed it is turning, Just like a water pump it can cavitate the air and be useless. Hence why if you use the wrong pitch of the prop on a plane at the wrong speed then the plane will loose momentum. Once again the same with a water pump, if the impellor's pitch doesn't suit the speed it is turning at it will can cavitate and there for loose efficiency.
understand madaz?
Chad, are you running standard internals? Or are you running some form of 26/30 or stroked 2.8 kit lol :P
Weren't you pumping out 230kw with the standard turbo's? That's nearly a 100kw power gain! Lol that's crazy dude.
Yeah it was 230kw before and as Luke said im just running GT2860-5's on a standard internal R33 GTR motor.
awesome effort chad!
Thanks mate, i also did a few mods to the manifolds and dump pipes to improve air flow, and also hollowed out the AFM's as they aren't used, which would of helped a little.
So the Skyline is now done. Thanks to Andew (blue32) for fitting the turbos for me. It made 316rwkw on the Willall dyno. Im very happy with the end result :P
thats a great result Chad
WELOCOME TO THE 300+RWKW CLUB.........
understand madaz?
yeah mate but i still cant help thinking that a RB20 pushing 15psi is going to put out similar heat to a RB25 pushing out 13-14psi
i only had on a few occasions heat soaking on my car so i know it does happen when you push the standard turbo too much
looks like a nice figure there Mitch but i believe there running less brake on the rollers to inflate your figure there Mitch
I agree steve my mates GT went from 224 at Aussies to 257 at KPM with the addition of underdrive pulleys only :P (which in reality would be 5-10rwkw at the most). Hows your car doing mate got it sorted?
Hi Lee na i minor issue of not being able to boost part 5k rpm has arisen will be at adrians friday to drop my front shaft and to smooth out the lower rpm and double check afr's as well
my future plans for big injectors may have changed also due to a slight drop in compression nothing to worry about but enough to know its tired and wont support 300 unless E85 is a lot more forgiving which i think it is more research needed and a chat to adrian
Guest
    • A few things that seem a bit off here. - why is there 2 BOV’s?  - the turbo smart BOV on the compressor housing, is it turned up ALL the way? I have seen this become an issue on old man Pete’s car. It would push open and recirc, turbo speed would rise and the boost pressure would do weird things. - stock head? Does that include springs? - tried a different MAC valve? Is it plumbed correctly?
    • Photo of manifold showing gate location? I mean, it's 6Boost, so we probably shouldn't be worrying, but always wroth knowing what the layout is. Plumbed back to atmosphere? Or into the dump?
    • Yes correct. Also, I'd avoid applying it to soft paint (however I doubt you'll ever have to deal with it in practice). So any paint that hasn't fully hardened, could be a 1k paint that never fully hardened or it could be a 2k paint that was laid down thick and hasn't yet fully hardened.
    • Bit of an update to this one. Having some issues on the dyno that held us back (boost spiking) and I want to pass some info over you guys and see what you think is wrong with my setup. The current readout on this dyno is 462rwkw on a low reading dyno so keep in mind it is a real world 500rwkw setup on a hub dyno. Don't read into the power figure too much as a sign of the issue. The short and curly of it is: 2.8 Litre Racepace build RB25 NEO N/A Head with VCT (internally standard however ) Borgwarner EFR 8474  Turbosmart 50mm Straight Gate + Mac valve 6Boost Manifold 4" dump to full 4" exhaust (nil restrictions) Wastegate plumbed back in and all angles in the exhaust system are acceptable and not too sharp. GFB SV52 BOV in cooler piping  Turbosmart BOV in EFR Housing   The issue we are having is it comes onto full boost for example at 4000rpm and spikes to 24/25psi, before dropping down to 17psi before slowly rising back up to the target boost of 23psi. It was extremely uncontrollable and the tuner actually had to ramp in boost progrssively with each 1000rpm on each boost setting we selected to try and reduce the amount of spiking. Sometimes we would see a drop of 10psi from the peak at the beginning of the run, to the low, until it took the next 500-1000rpm to stabilise back up to the target boost. The tuner is pretty confident that the straight gate is just a poorly designed product and leaks too much boost upon cracking the gate open and theres no way to fix it other than going to a poppet valve. He's also confient theres no ignition breakdown or floating valves. The fueling is extremely stable as well. Turbo speed is somewhere around the 109,000rpm area. The spanner in the works for me is that prior to this Borgwarner and StraightGate, the car was tuned on -5 twins at a diferent tuner, and he also had issues controlling the boost with it spiking around the same rpm range, so to me this sounds like the same issue and it can't be anything on the turbo side as this was all changed and I think the behaviour is extremely similar, if not the same. We also removed the mac valve and did a run on wastegate pressure and it still spiked and had the same behaviour. My thoughts on possibilities are: Boost Leak VCT Cam Gear isn't reliably activating consistently - (On this however, we did a run with the VCT disabled and the boost still spiked) Turbosmart BOV is not handling the boost? However this seems unlikely to not be able to handle 20psi. I have a couple of logs that I can't make sense of if anybody knows how to read them and can obtain further logs of other parameters if they are not enough, happy to pay for anyones time. The dyno readout with the power figure is the most recent last week. The other picture is from two weeks prior to that where we couldn't break 400kw (we removed the cat), however the issue of the boost control persisted. @Lithium @Piggaz @burn4005 @GTSBoy @discopotato03 I've tagged those that were quite active in recent pages here, no disrespect to those that know turbos well but I missed tagging. Cheers
